Coil packs and spark plugs -- anything else?
Lifetime Member
Lifetime Member
'06 CS. Ordered 8 of each:
948-602-104-21
999-170-218-90
Anything else I should look for while I'm in there??
Thanks,
Matt
948-602-104-21
999-170-218-90
Thanks,
Matt
Formerly 'slevy951'
That mount on pass side that bolts engine to body on top. Check the bushings and report back how they are. I've not replaced in my '04 yet but it's on my radar. Air filters.
Lifetime Member
Lifetime Member
I also ordered air filters. Do you know what part number the mount you are referring to is? Or are you just asking me to check out the bushings?
Scott, is that you? I just noticed your signature!
He's referring to the engine torque arm you have to remove to replace the plugs and coils. 955-375-101-13-M100. Just did my coils and plugs on an 05' CTT with 38k miles and replaced the torque arm after seeing that the rubber bushing was very deteriorated.
Lifetime Member
Lifetime Member
Is that the same as 955-375-101-13? Won't come up with the M100.
Lifetime Member
Lifetime Member
Looks like M100 is insignificant to the part number. I ordered the 955-375-101-13 part and it will be here Tuesday with the coils and plugs.
Thanks for the inputs.
Lifetime Member
Lifetime Member
For your SA, only two coils were cracked on the driver's side bank. All others looked good. Plugs looked great, with a minor amount of oil near the washer but no carbon or buildup of any kind at the tip. All tips were tan colored.
Definitely happy with what I saw.
Lifetime Member
Lifetime Member
I did not know to change them or I would have (see my original question). The car does not have a burning oil smell at all.
Lifetime Member
Lifetime Member
