Best place for mic
Best place for mic
I have an 04 S and going to install an aftermarket stereo. Where would be the best place to install a mic? If I had a factory mic, where would of that been located?
Factory mic in factory location, but aftermarket usually works best on the right of the sun visor.
I installed mine in the overhead console/sunroof control for my Mobridge. Everyone say's phonecalls sound crisp and clear but that probably depends on the Mic a lot.
Best place is clipped on the headliner edge against the front windshield, between the sun visors. Easy to route the wire to this location - just wedge it under the headliner edge without having to remove the headliner - just pop off the A-pillar cover.
This way you don't get wind noise if the driver's side window is down.
I've asked while making phone calls when I first installed and everyone said it sounded good. My mic is the one that came with the Mobridge. Obviously installation and mic quality are equally important.
Rocky Mountain High
That is the factory location...
Anyone tapped into the factory mics for a Mobridge install? I have the factory mics and would like to use them if possible. I have heard that they may not be compatible.
Thoughts?
Cheers,
TomF
Thoughts?
Cheers,
TomF
