No sound... cold morning
I started my car early this morning (-10° F), turned off the radio like I normally do and when I came back to the car it would not turn back on. I have display I have navigation everything seems to be normal except I have no sound coming out anywhere. I have gone through and checked all the fuses nothing seems to be blown, I don't know if there is anything else to check before going to the dealer. Does anyone have any suggestions. Thank you
Intermittent amplifier failure is pretty common. If you can unplug the amp and plug it back in, most of the time this will get it working again... Until it happens again. If you have a warranty, let the dealer replace the amp.
I have the same issue.. based in Chicago.. Radio made some interference sounds and then nothing.. have restarted the car a few times. I have read that i might have to unplug the amp wires and this might solve it.. going to wait til its a little warmer outside.
Thanks for the response. I figured it out accidentally by removing and replacing a fuse in the right side fuse panel. I must have reset the amp that way. Weird. I assume my battery was just replaced with the CPO process in july.
Team Owner
Beat me to the punch, that's what I was going to suggest. Here's the thread in question: https://rennlist.com/forums/porsche-...m-anomaly.html
Yep, glad it turned out to be an easy fix.
