PCCB Life on Cayenne
I am sure that there are many threads on this topic but couldn't find any specific to wear. I have 20K miles on a 2012 CTT equipped with PCCBs and yesterday my service tech indicated wear on the front brakes (he rated them 7 out of 8 on his chart) which surprised me - I cannot see any wear visually like you do on iron rotors. Didn't have the opportunity to speak directly with the tech and the service person was clueless.
I've had these are two 911s and have always been told to expect 200K minimum for spirited but not track level driving - my GT3 has 65,000 street miles and no wear that I can detect (don't know about the pads). Does anyone know what to expect from these ceramics on a Cayenne, has anyone experienced wear on PCCBs? I love the brakes and don't mind paying for them "once," but I would not like to pay for replacements.
My service person also told me that "Porsche" on replaces rotors and pads, never just pads. But throughout these forums I see reference to people replacing just the pads on PCCBs - is replacing both Porsche protocol or just my dealer?
Trucker
...I have 20K miles on a 2012 CTT equipped with PCCBs and yesterday my service tech indicated wear on the front brakes (he rated them 7 out of 8 on his chart) which surprised me - I cannot see any wear visually like you do on iron rotors. Didn't have the opportunity to speak directly with the tech and the service person was clueless....
....My service person also told me that "Porsche" on replaces rotors and pads, never just pads. But throughout these forums I see reference to people replacing just the pads on PCCBs - is replacing both Porsche protocol or just my dealer?
I have around 100k miles on 3 PCCB (street) cars and have only had to replace front pads on one car.
As far as Cayenne and PCCB...I only know of one guy who ordered his CGTS with PCCB but then had to swap to iron rotors right away since he was a weekend (tow) warrior and PCCB was not recommended for 6K'sh lb of towing....
I am sure you are correct - I went out this morning and inspected the rotors, there is not even the hint of a ridge line on the rotor. The pads wipe past the OD and the inner wear mark is just that - shiny surface versus the untouched ceramic, very smooth - no lines. So you are correct, it's the pads only and I will replace these early per your recommendation. My 2010 GT3 went 65K miles with no apparent wear as I recall and I just placed an order for a new GT3 with PCCBs - love these brakes even though I realize part of the appeal is psychological.
My dealer is owned by Penske and they are fairly rigid in their approach - especially the customer service people, and there is a lot of turnover within that group. However, their service techs are outstanding with 20 plus years of service, they've worked on my cars for all those years and always get it straight from them. In this case, I wasn't able to able to speak with them.
Trucker
….My dealer is owned by Penske and they are fairly rigid in their approach - especially the customer service people, and there is a lot of turnover within that group. However, their service techs are outstanding with 20 plus years of service, they've worked on my cars for all those years and always get it straight from them. In this case, I wasn't able to able to speak with them...
And I am a big PCCB fan, albeit they are too expensive IMHO…best of luck.
The GT3 was amazing, very low and muscular as compared to the standard 991 - very striking in the flesh. Also sounded incredible! I has been offered the car as the purchaser has decided not to take it, but as I am #1 for their next allocation I decided to wait - car was not optioned the way I will order mine, and for the money I can wait.
By wear at 20,000 miles you must mean pads, and not rotors I hope? Your tech is definitely incorrect about having to replace both rotors and pads. Pads can be replaced without the ceramic rotors. And the typical recommendation on the pad replacement is OEM. The other tribal rule is to not run the pad down all the way and run the risk of ruining the (expensive) ceramic rotor; say swap them out with 30%-40% life left....
"they will replace pads only on the PCCBs even they don't replace pads only on standard brakes"
This seems odd to me me. My philosophy has always been to change pads early and often on conventional brakes, to keep heat away from the hydraulics for long caliper life, and the brake fluid in the calipers operates at lower temperature. A thicker pad provides more thermal insulation between the pad/rotor interface and the caliper poisons, making for cooler brake caliper fluid and piston seal temperature. That makes for longer brake caliper life. I only replace rotors if there is too much wear or some sort of warping problem. I never machine rotors as it removes to much metal. The new pads and rotors quickly machine each other in service and there is some smoothing of worn rotors that occurs with this approach.
That's my approach. In practice it is cheaper and provides greater caliper life, and I'm sticking with it.
What is the consensus about whether the break pad warning sensor gives adequate notice to replace? I have 34k on my pads and no sign of a sensor light yet.
