Is there a valve cover gasket diy?
10-29-2013, 07:52 PM
Is there a valve cover gasket diy? Im planning to do mine very soon on my 2004 cayenne s v8. Thank you
10-30-2013, 03:29 AM
10-30-2013, 11:11 PM
10-31-2013, 01:49 PM
If no one has one I would look on the PIWIS site.
Follow instructions
in this link.
Good luck.
11-14-2013, 10:13 PM
Thank you. For anyone who cares i did it without any instructions . Gaskets were hard as a rock shattered like glass when removed. The crankcase vent tube that runs from one side of the engine to the other was really brittle and snapped upon removal. Other than that just take your time
08-31-2014, 08:43 PM
08-31-2014, 09:00 PM
Jeroen,
There will be one valve cover gasket PER BANK of the engine. So you will need two for a V8.
08-31-2014, 09:07 PM
There is only one bank leaking, should i do both?
08-31-2014, 11:45 PM
Formerly 'slevy951'Lifetime Rennlist Member
09-01-2014, 08:06 AM
Yes, do both. If one is leaking, the other isn't far behind.
09-01-2014, 03:13 PM
There is a spark plug gasket that runs up the middle of each cover as well. You may also consider doing the seals for the variocam solenoids
12-17-2016, 06:25 PM
Brittle PVC vent hoses
cosmoracing they made the silicone breather hoses for Cayenne-S and turbo in replacing the brittle PVC vent hoses
2004 ,
996 ,
cayenne ,
chayenne ,
cover ,
diy ,
gasket ,
pet ,
porsche ,
rennlist ,
set ,
turbo ,
v8 ,
valve
