Key Fob Programming Failure
When I picked up my CS in December, '12, it came with one active key and one non functional key (battery was dead).
I thought a new battery would revive the second key, but no luck. Ended up taking it to the dealer for programming. They were able to get the second key to work, but I ended buying a new key too, just in case
So, if you are counting, there are three active keys and they all work.
The dealer seems to be, no pun intended, the key. :-)
Looking at the PIWIS video it says, if I remember correctly, that an old key cannot be reprogrammed not that it is not permitted.
2011, 2014, cayenne, fail, fob, key, keys, panamer, panamera, porsche, programing, programming, replacement, reprogrammed, reprogramming, turbo
