Looking at this GTS . PHOTO Inside . Should I pull the Trigger?
If you decide to go that way, then get a quote for the CttS coolant pipe kit from Sunset Porsche http://www.sunsetimports.com/portlan...porsche-parts/ at least as a reference, I would proffer.
Sunset Porsche had the best price I could find when I did mine.
Make certain the kit includes the 'T' pipes, too.
CPO is a major plus on any out-of-warranty Porsche where the small stuff often costs like big stuff. Things like hatch cylinders, AC, instruments, air suspension...all covered w/CPO. Its saved me $2K on such things in less than 6 months.
Is PDCC that bad-***? I don't need anymore stuff to break down in the future
Plus...have to wait another year or so till they come down to the same price? In the mean time my current 08 CS depreciates more and I lose the last year of CPO, which is a good selling point right now for it.
Word. I just think the 06 will annoy because u are used to face lift and the gts isn't enough of an upgrade to warrant the fuss. But you know best whats important to u.
Redcc - I don't think it's unreliable. I really like driving hard sometimes and so for me it would be mandatory reason to upgrade. I also would want more power which to me the gts doesn't offer a big boost. But you may not care about that stuff. GTS does flex more in the looks dept so YMMV.
HA.....get that 1 in writing. I bet the guy thinks he is popping the hood and swapping a rubber hose from AC Delco. It's $575ish in parts and 6-9 hours labor from what I have read. Read through the coolant pipe sticky.
Is the 2009 GTS that much lighter than the 06 Turbo S? I see the Turbo S at 5668 pounds and the GTS at 5376 pounds.
Are the turbos any different on the 08 versus the 06? I know the compression ratio is much higher on the 08 and newer engines versus the older 06 4.5L engine.
nothing that a hammer and a pick won't do to get the leak going......I hate big corporate schemes that sneak their way out of recalls....in a "let's wait until it breaks to fix it" mode
My understanding is when the coolants pipes start leaking...you can go from wet to dry in no time and seize the engine...or the coolant leaks onto the starter and fries it...which then requires the entire engine to be pulled to fix the starter....
anyhow, I trust the service guy...I know his family and where he lives...if he tells me something, I'm sure it will get done in one way or another
When your pipes burst it is important to clean out the coolant as quickly as possible. The starter will be soaked in coolant- as it sits directly below the pipes, there is no need to pull the engine to replace anything. A bigger issue arrives when that coolant eats up your torque converter seal.
Ah...good to know...I thought the starter rusted or something. Torque converter seal then mean whole tranny pull. Propylene glycol is that caustic to seals???...not good for dogs or cats either?
Would easily take the GTS. The Turbo S is older.....looks a lot older. The maintenance costs are going to be same as if it were new. I just traded in my SL55 towards my Cayenne because it also had a long laundry list of stuff that breaks and it's NEVER cheap. I couldn't justify spending that on a car that was 7-10 years old anymore.
I have a Cayenne S now and find it has PLENTY of power for an SUV....I wouldn't think the power difference between a Turbo S and a GTS is going to be enough to buy an older Turbo S.
I hear you...and this is a line of thinking that's up my alley. The 2006 Turbo S does come with 2 year CPO. The 2009 GTS is nice looking though.
On a side note, I read around here that the 2006 CTTS could probably be a collector because only 600 came into the USA? Not sure if this is an accurate assumption?
On the 09 CTT in order to match the performance of the 05 CTT it has to be driven in Sport mode, getting it going in normal mode takes a bit of effort. Even with PDCC I'm still not convinced that the 09 CTT handles as well as the GTS did. My 05 CTT very, very rarely exhibited the "turbo lag", probably better described as throttle lag, that others mention so not an issue for me. Bear in mind that there is a 340 hp engine underneath the turbos so it should still have some instant go.
And to all those naysayers out there...the GTS is a completely different animal from the S.
Thanks bro for the advice!
I won't be doing much highway driving...mostly city (south florida)...and the streets are not bad here as far as pot holes or stuff like that.
So you feel this 2009 GTS trumps the 2006 CTTS with CPO? For driveability and comfort, etc.
How much is a 2 year CPO worth in dollars....or I guess "piece of mind" for that matter?
I have driven a 2006 CTTS, and it seems smaller than the 2008+ Cayenne. The TT is a monster though when you smash the pedal.
I had the 09 GTS first (in 2010) and concurrently ran the 05 CTT when my work moved to a 170 mile round trip commute. I drove the 05 CTT from 55,000 miles to 122,000 miles in just over 2 years all on the original coolant pipes and cardan shaft. The CTT was a quick and competent highway car but out on the twisties and the GTS really showed it mettle and was a much more entertaining car to drive.
