Water Distributor Failure - 2008 CTT @ 50k miles
Originally Posted by 993BillW
I'd be curious how much expansion/contraction the JB Weld could handle (dissimilar metals).
I'd research the OEM adhesive/sealant. Is there a Porsche shop procedure for this? Like the MDs say..."Do no harm". And I still recommend contacting Porsche. It's pi**-poor connection design for a pressurized system.
I seem to recall some guys re-gluing the pipe on the GT3 engines and drilling a small hole in the side of the aluminum manifold, tapping it, and installing a set screw to prevent the tube from working loose again. I think there's a thread on the 996 GT3 section.
I am not sure that we have the same problem but I have an 08 CTT that all of the sudden let loose a bunch of coolant on the floor at about 85K miles. Barrier (dealer) towed it and after evaluation ordered a new part from Porsche that superceded the original part. It was a several thousand dollar job but they covered about 1/2 of the cost. Before trying to repair the original I would check to make sure that there were not other flaws with the factory install.
Same problem different model 2008 Cayenne Turbo
Hello New member here, long time viewer first time caller.
I had this exact same problem as the OP listed with my 2008 Cayenne Turbo last week. Had to drop the engine and replace the distributor housing using parts:
948-106-154-01
948-106-069-10
948-106-026-04
948-106-061-06
and a few others... Total cost was >$3300 for this episode. Not happy, don't feel this is a normal type of thing to have happen to a car with 30k miles filed a safety complaint on it to document it (NHTSA ID Number: 10547588) in case it helps anyone else including porsche fix this problem and compensate us for the repair costs. I am otherwise problem free on this car and I love it so much.
948-106-154-01
948-106-069-10
948-106-026-04
948-106-061-06
Toddimus
What did you do to fix this problem I have an 08 turbo cayenne and had the exact same problem happen to me, where the glue came loose and pushed the coupling out. thanks any help would be appreciated do not want to pull engine
Sorry, I haven't checked in for a while. I did fix it myself, with a very low cost solution (with a few extenuating circumstances). The expensive part was the $100 of super coolant I bought to re-fill the system. It's a long story, but the extenuating circumstance was that the plastic "plug" that keeps the drive coupler to the high pressure fuel pump broke when I pulled the pump out to access the water distributor. It's a simple, white plastic part that should cost $0.25, but Porsche wants $40 for it. That's just criminal!
I prepped the surfaces of the cast part as well as the tubing sleeve with some coarse "dremeling" of the surfaces. Then, I used some acid to etch the surfaces to remove any oxidization for a better adhesion. After a careful rinsing of the acid, I used JB Weld to glue the parts back together.
It looks to be a permanent fix, but if I had to get back in there I would do as jpoint suggests:
I thought about doing just that, but it's pretty tight back there and I didn't want to make a "mess" of the cast aluminum distributor back there. If it fails again, I'll add the set screw and fix it for good!
Slots, I'm sure that's the way the dealer would want to fix it. I bet their updated part has some sort of secondary keeper feature to prevent this from happening again. It's a part failure and Porsche should cover this as part of an extended warranty and/or recall. Not everyone wants to dig in like I did and fix it "shade tree" style. Ultimately, we both ended up with a fixed car but I'm not $3300 lighter like you are. You have a warranty on it though!!!
See above for my procedure. It really wasn't that technically difficult, but it's a very tight space and it helps to have small hands, so I enlisted my wife and son to help...
948-106-154-01
948-106-069-10
948-106-026-04
948-106-061-06
948-106-154-01
948-106-069-10
948-106-026-04
948-106-061-06
Last edited by Toddimus; 10-29-2013 at 12:52 AM. Reason: Got rid of image from one of the quoted sections
This was not covered by warranty as mine on my 2008 has now gone expired. Seeing as we are on the 5 year expiration window I would expect more people to start reporting this problem that are required to spend >$3000 to fix. With this in mind I did document this problem on the Safecar.gov site (report number 10547588).
Like the last few years of coolant pipe problem people I believe this site and others encouraging people to file these reports on the safe car site was what ultimately resulted in Porsche doing a recall and refunding people for the repair costs.
This is a dangerious design flaw which at high speed could result in accidents and engine fire from overheating. I lost 8 gallons of coolant in just a few seconds in a big pooof. This car was always serviced and has very low miles and treated with kid gloves and other than this episode was the best car I have ever driven. And I still feel that way but I'd like my 4k back tyvm.
Cheers to this site where I found the OP with the same problem so its not just in the turbo cayennes.
slots
slots
The V8 Porschephile
In the tech notes section of last month's Excellence magazine, there's an in-depth discussion about the coolant distributor failures that have been plaguing the 957 Cayenne as well as certain 911 models. The bonding agent that is used to fit the hose pipe extension to the cast manifold fails under high heat conditions.
Also, there's the potential hazard of damaging certain transmission components after such a failure. An interesting read...
+1 JB Weld as a fix that may last for another 5 years. Clean well first.
Cheers!
Not much to lose by trying this repair. But once complete, I would run the system up to full temperature with a coolant pressure gauge mounted in place of the cap. Make sure the system pressure is not pegging the gauge. A blockage in the system somewhere can cause excessive pressure, and it will find the weakest link. A blockage can be caused by a number of things; failed thermostat, bad auxiliary cooling pump among them.
