Looking for consensus: cardan shaft..?
I have a 2005 V6 auto with 110k on the clock. I'm getting an intermittent loud 'thud' at low speeds, briefly followed by a deep throbbing. It clears up as I accelerate, no problems at higher speeds/RPMs. Started a few days ago, seems to be getting louder and more frequent.
I'm thinking cardan shaft.
Okay, I reviewed a couple of the cardan shaft threads and then crawled under the truck. I can see the bearing assembly and it looks like it's in good shape externally. Should I see any external wear, or is it all inside?
Oh, yeah: I've been expecting it since I bought the truck. I just want to make sure my diagnosis is correct before I buy parts. As I said, externally, that assembly looks fine.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Not as good as a guess...
I started searching this morning - can't remember the terms - and I found a thread that described a transmission problem with a thud and vibration. I dismissed it because I was pretty happy with the cardan shaft diagnosis, but after looking pictures and reading descriptions of the disintegrated rubber around the carrier bearing, I was suprised to see that mine looked to be in good shape.
Unfortunately, I haven't been able to find the transmission problem thread again. So, I thought I'd ask.
its funny because mine would get more unhinged the more i accelerated. Would start out mellow at low speeds and then turn into a crazy vibration and thumping as i got on the gas.
Can I just squirt some 3-in-1 in there and spray the rubber with Armor-All?
I talked to my brother and he's up for just replacing the bearing support. That will be an Independence Day weekend project.
Further updates as events warrant...
