Brake replacement suggestions 955 CTT?
It's time to replace the pads and rotors on my 04 CTT.
Thinking about just ordering the ECS tuning kit to make life easy
http://www.ecstuning.com/Porsche-200...Kit/ES2602307/
Unless anyone has any other non-$1000 suggestions.??
I tow with my CTT, have autocrossed it, tracked it, 4 wheeled it, running 32" tires in the winter, travel the Colorado Rockies mountain passes a lot with it in winter. Just to give you an idea of use. Yet, I still seemed to make my stock set last 107k
I sourced Powerslot rotors from LPI racing last year. Working fine, but mine is only a daily driver. Steve can help you with pad choices. Great service. Wanted drilled and slotted but only slotted were available at the time. I have a 2004 TT with large diameter rotors (330mm??) in the front.
Got all the stuff for well under $1000. I seem to recall $600 to $800.
