Took delivery of my '06 Cayenne Turbo S
#47
#48
Got it, thanks. Ppi scheduled for tomorrow and i feel it's going to come out positive. :-) I can't wait to join the club.. Has anyone ever used a ppi in negotiating down the price of a car? So I am thinking if the ppi is bad, i run away. if fair - I offer $20000, if ppi is medium/avg $21000, and if the ppi is super clean - not even bring it up in my bargaining discussion, but offer $23,000.
Dealer is asking $27,500.
I am concerned there aren't many 2006 - 2008 Cayenne Turbo S available for sale within 100 miles of me. at least not below $35K
Your thoughts? since you are experts and have probably sold some of this in the past.
For 957 2009/10 had Turbo S
Considering that a regular turbo was around 100k base, and a Turbo S was 25k or so more for not much more for the 25k, I can't imagine a lot where sold
#49
2006 Cayenne Turbo S
First year of the Cayenne turbo S was 2006 so it feels like a collectors' item. I like that..It is not very often one is making a great deal of a Car dealer so thanks to everyone for your comments. Excited and can't till tomorrow. I'll post pics once it's done. Thanks.
#50
That and, IIRC, only 600 were made world wide.
#51
I put a deposit on a 2006 Porsche Cayenne Turbo S with 89K mileage in the North Jersey and New York City area. The Dealer was asking $27,800 for the car, but we now negotiated to $29500 for the car with 3 year/36 K extended powertrain warranty included (Through Fidelity Warranty Service).
The 3 year warranty separately costs about $4500 and includes coverages for the engine, transmission/transaxle/transfer case (clutch assemblies and all component parts are not covered), drive axle, and additional hybrid/plug-in electric/compressed natural gas components. Does not cover Steering, Brakes, Air Conditioning, Suspension, and Electrical.
Courtesy of Rennlist and thanks to you, i am getting a ppi done. The dealer has also confirmed the following:
1. Tires – just replaced
2. Brakes – just replaced
3. Coolant pipes – checked out
4. Cardan shaft –in good order. Test drove and car was pretty steady and was not all over the place.
5. Rear Hatch Shocks – yet to check
6. Starter - yet to check
7. Torque Converter seal - yet to check
8. New ignition coils - yet to check
9. PWIS Headlight - I read from another 2005 owner that sensors may require adjusting. Is this common?
Questions:
• Is this a reasonable offer for a 2006 Cayenne Turbo S?
• What other items should I look out for?
• Are the extended warranty coverages adequate for this car?
I am moving from a 2008 Range Rover Sport that only required the oil change, brake and tire replacements so I am concerned and doing all due diligence.
Thanks advance for your advice, much appreciated indeed.
Questions:
#52
#53
wow, so i'm not the only one who burns oil in an '06 Turbo S? I go about 1000-1500 miles between quarts. I have over 180,000 miles, but it doesn't seem to burn any more now than 100,000 miles ago.
#56
I just wanted to post an update to this thread.
Purchased 2/2013 - 108k miles.
Today 3/2017 - 148k miles
Besides routine maintainance, I've had to replace two things:
1. Carden Shaft - shortly after delivery
2. Plastic Coolant Pipes
I have opted to do the following:
EVOMS Cayenne TT/TTS V-Flow Intake System
DV18 Diverter Valve EVOMS Cayenne TT/TTS (Only)
Fabspeed Secondary Catbypass Pipes Cayenne S/GTS/TT/TTS 955
IPD 76mm Plenum 955 Cayenne Turbo/TurboS
955 Cayenne Twin Turbo S 4.5L V8 (03-06) EVOMSit Intelligent Tuning
High Performance Cats
Needless to say I cannot be happier with the Cayenne. With all the upgrades she screams - holds the boost like crazy and pulls on almost anything I've come up to on the road.
Thanks,
Erik
Thanks,
Erik
#58
Thanks,
Erik
Thanks,
Erik
#60
If the cardan shaft is "new to you" then you didn't read a word of this forum before buying yours Do the Jimi Fix and sleep soundly [assuming the bearing is still good]
