Horn Replacement - How to get the dang connectors off?
Old 11-24-2014, 04:22 PM
XR4Tim
XR4Tim's Avatar
Originally Posted by nabuhodonosaras
Now i've been pissed big time, removed left wheel plastic cover see no horn, removed right side no horn.
Where the hell are those horns on 955 Turbo, i bet it's different than "S" model course where is "S" model horns, there's intercoolers on Turbo.
Please help hate going muted.
They're in the same spot as on the S models, but the intercoolers prevent access. You have to remove the bumper cover to get to them on the Turbo. The good news is that once the bumper is off, they are very easy to remove and install.
Old 11-25-2014, 07:58 PM
CarreraCup03
CarreraCup03's Avatar
one of my horns went our on my 2005 CTT. I replaced both with the Hella Supertones. I bent the mounts they came with, and they fit in the stock location. I also cut the plugs on the factory harness, and lengthened the wires. I did have to take off the front bumper.
They came out great, and I expect these to last for a long time. pretty loud to.
Old 12-06-2014, 12:25 PM
nabuhodonosaras
5th Gear
nabuhodonosaras's Avatar
Thants a lot
Old 02-21-2015, 02:28 PM
Todd Simons
2nd Gear
Todd Simons's Avatar
Default Panamera Horn Location
Does anyone know where the horns are on a 2013 Panamera and how to access them?
Old 02-22-2015, 02:09 AM
deekay911
deekay911's Avatar
Might want to try the panamera forum....
Old 08-09-2016, 09:58 AM
125shifter
125shifter's Avatar
Do you need to use the relay that comes with the Hella Supertones or just connect straight to existing wiring?
Old 05-05-2021, 11:06 PM
wilfred
wilfred's Avatar
Replaced both horns on my 2006 Titanium S and found it easiest to stick a pocket screwdriver at the red arrow then wiggle and pry at the same time. (Thank you XR Tim for the picture.)
I also found it easier to turn wheel out then pull out liner. Stick a small camping light inside helps too. The first one took 30-45 minutes but the second one took me like 10 minutes.
Old 05-05-2021, 11:29 PM
TRINITONY
TRINITONY's Avatar
hmmm....don't even know if mine work. Will have to try it tomorrow...
Old 05-06-2021, 10:45 AM
Brainz
Brainz's Avatar
Do yourself a favor and buy one of these:
Amazon Amazon
And squirt some silicon spray on there to loosen up dirt that may have lodged in the gap. Then give the connector a squeeze "closed" to break/loosen the seal, and then use the tool above to pull it apart. Those connectors are all over the car and can be stubborn without the right tool.
TRINITONY (05-06-2021)
Quick Reply: Horn Replacement - How to get the dang connectors off?
