So what did you do to your P!G today....
09-22-2012, 09:19 PM
I'll start..... Changed the spark plugs, checked the coils and drive belt.
09-22-2012, 09:50 PM
Washed it and bought a brake controller so it can tow our new travel trailer
09-22-2012, 10:03 PM
Just had the GTS tips installed
09-25-2012, 07:26 PM
Had an IPD plenum and upgraded diverter valves installed
Boost builds up quicker and smoother as well seeming to hold up for longer
09-25-2012, 07:49 PM
Used it for the first time for its utility.
09-26-2012, 01:54 PM
Quote:
Originally Posted by
jerry joseph
09-27-2012, 03:00 PM
Drove our 2012 from the coast with 2 dogs and luggage. Killed a lot of bugs.
Now washing her.
09-28-2012, 04:27 PM
Picked up parts from local P dealer, the plastic nut clips for the rear taillights, this better fix the non flush issue with LED's on the right rear!
09-28-2012, 09:18 PM
The V8 PorschephileRennlist Member
You know....the typical things that are required with all German automobiles.
Topped her off with Mobil 1, fixed a rattle coming from the mirror control at the A-pillar, fixed the rear seat release lever, re-glued the passenger seat belt housing (again), lubed the glove compartment latch, silicone-sprayed the driver's side felt window track, plexus'd the rear plastic trim below the rear window (if it's good enough for an F-16.....), touched up the rock chips on my hood, cleaned the engine compartment & wiped down the polarized instrument cluster with optical-grade wash solution (damn streaks!).
09-30-2012, 04:44 PM
Touched up the scratches that (someone who shall remain nameless) put on the passenger side after rubbing up against a cement pole.
09-30-2012, 05:30 PM
medtech
Hope it was not too bad
Saw a white MT Spyder at the dealership..what a cute car-tempting
10-02-2012, 04:35 AM
jerry joseph
Oh, it's bad, but I'm just going to DIY it and live with it. It's not worth repainting an entire quarter panel.
Jerry, just pull the trigger on a Spyder, you won't regret it!
10-02-2012, 10:34 PM
Cruisin'
Got hit by a taxi running a red lucky for me there was witnesses
Reason: added details
10-03-2012, 02:38 AM
Ouch!
But easily fixable, I hope!
10-04-2012, 12:46 AM
It was delivered!!
