Porsche Cayenne Turbo - Air suspension fault p1772
so i have this fault. I have researched and looks like i need to replace or repair compressor. I understand that i need part no. 7LO 698 030 for the repair kit but i cannot find it to buy in the UK. Have read on forums about guys buying for $20 but as far as i can see its more like $150?
Can anyone point me in the direction of this part in the UK for a reasonable price or somewhere that will at least deliver to UK.
http://www.ecstuning.com/Search/100698010A/ES289283/ At least in the states it's on a National Backorder but you may find someone that has it in stock. I have two on backorder from Jim Ellis Porsche but I didn't try ECS.
My kit solved my problem, error 1772. Be careful when you get it that you install the rubber piston ring on correctly, the small gap on the backside must meet the pin in the compressor piston.
1772, air, cayenne, code, fault, faulty, forum, porche, porsche, replacement, sensor, suspenison, suspension, suspention, turbo
