Air Suspension Faulty Message
Been getting this warning messages once in a while. IT goes away after a few seconds (or if I restart the car).
Air suspension seems to work fine though. I can change to all different levels without issues, even when the warning light goes on.
Any idea what's goin on? Am I in for some major or minor repairs?
Rocky Mountain High
You probably just need to have your air compressor rebuilt. It's not expensive.
I would agree usually its the compressor not building pressure quick enough and you get a 1772 fault, I would get the fault read before I replaced the compressor its not cheap for a new one.
Nice to have you back brad!
Just as the orig poster stated, would appear on initial start and disappear after the subsequent restart.
Was 4 years ago and never reappeared after the battery change.
Welcome back by the way....
Hmmmmm surprisingly enough this started happening after my battery died from a navigation deck installation.
Maybe I'll see if a new battery helps. Is there a quick and easy way to check battery strength?
