What is this leak? Torque converter seal, maybe?
1 Attachment(s)
Okay, '05 V6 P!g here and I've got some fluid on the garage floor. It's not oil; I believe it to be ATF, but the floor is dirt-over-concrete (heh) and I can't tell yet (I'm going to put down a pan to catch it, then I'll know). The location is just inside and at the back of the passenger wheel well.
Condensation
Originally Posted by wirunner
(Post 9554171)
Condensation
Hmm...
It's persistent and slightly oily-feeling. It only just got warm enough for the A/C to be on, so it may be condensation picking up road oil from the undercarriage. I'll keep an eye on it. If it is the torque converter, where will the puddle be? |
Any odor to it?
Can't tell really from the pic but if it's right of center then I would be inclined to think not the converter. I would expect a converter leak to be directly midline since that usually the lowest point a leak will drop from. Hopefully others with more knowledge will chime in. After parking the car having had the AC on, get down and watch to see if it's dripping actively at that moment, it should be since part of AC's job is to remove moisture from the air. You could also put a white plate under the drip to determine color better. Or get under the car and look for the source. |
That small stain is post-drive: I moved the truck from the garage in back to the street out front; about a quarter mile, all told. I crawled underneath and felt around as best I could and no moisture on the undercarriage directly above the stain. I haven't noticed hard shifts or any noise, either. I have to go out a little later, I'll give it a good look then.
A torque converter leak will show in the center (left to right) and just behind the front wheels (front to back). That looks more like A/C condensation to me (unless you moved the car). Also, windshield washer fluid drains off of the cowl just behind the right front tire, if you've used your washers lately.
Originally Posted by Shawn Stanford
(Post 9554232)
Hmm...
It's persistent and slightly oily-feeling. It only just got warm enough for the A/C to be on, so it may be condensation picking up road oil from the undercarriage. I'll keep an eye on it. |
My car always drips there, it's the AC
