Cayenne 958 V8 DIY Oil Change w/pictures
Old 05-14-2012, 07:37 PM
Slow Guy
Slow Guy's Avatar
Originally Posted by XR4Tim
The PIWIS is more accurate than the instrument cluster. It shows the oil level value in millimeters, and there is a chart that shows how many mm is considered "full" depending on what type of oil level sensor, and what software your vehicle is running.
I wouldn't be too worried about reading it with the instrument cluster. At worst it may be ½ quart off. Great write-up!
Interesting. Thanks for the info. Wonder why they don't put that kind of accuracy in the inst. cluster since the (pick up) sensor is most likely the same?
Old 05-14-2012, 08:48 PM
Mike in CA
Mike in CA's Avatar
Originally Posted by w00tPORSCHE
You are god sent Mike.
Too kind, Amar....
Originally Posted by Andy E.
Nice write-up Mike! Are those salt stains on the sub-frame?
Thanks Andy. I've never been anywhere with salted roads. We have hard water from our well so it could be residue from that but I don't typically hose down the engine or under the car. Probably just dirty splash from puddles; there are openings where water can get in from the sides. Should have cleaned it while I was under there but too lazy.....
Old 05-14-2012, 09:37 PM
Slow Guy
Slow Guy's Avatar
P!g frolicking in puddles, nothing wrong with that!
Old 05-15-2012, 10:18 AM
911SLOW
Admin
911SLOW's Avatar
Originally Posted by 993BillW
Just because I feel like being an *** today you could only manually check it with a dipstick or counting the amount of oil you put back in during the change. Using a PIWIS tester is still doing it electronically. I don't imagine they have a 2nd sensor reserved for the PIWIS tester so they must consider the electronics in the gauge setup to be inaccurate. That's weird.
Agreed but I used Porsche's phraseology.
Old 05-15-2012, 10:35 AM
Slow Guy
Slow Guy's Avatar
Wouldn't it be so much easier for Porsche (and other mfgrs. too) to just go back to the simple (and reliable) dipstick? (KISS principle anyone?) I wonder how much time and $$$ Porsche has expended on oil level related issues?
I went through much the same thing with my wife's first BMW (a '07 328 H/T Conv). I did the first oil change myself and intentionally left it almost 1 qt. shy when I refilled it. It was almost a week before the on-board system registered the oil as being 3/4 qt. low. I never trusted that thing after that. It's one thing to be inaccurate on a dry sump car w/ and 11 qt. capacity, quite another on a wet sump w/ 6.5 qts. (IMHO).
Old 05-15-2012, 10:43 AM
911SLOW
Admin
911SLOW's Avatar
How dare you.. What if a drop of oil hits my Chanel?
Old 05-15-2012, 11:07 AM
Slow Guy
Slow Guy's Avatar
My apologies Sir! I failed to consider that. A fresh drop of oil or 2 would greatly enhance my ensemble though.
Old 05-15-2012, 12:20 PM
XR4Tim
XR4Tim's Avatar
I'm sure they don't want owners keeping an eye on exactly how much oil their car is consuming, especially if it's minimal.
Old 05-16-2012, 12:12 PM
Slow Guy
Slow Guy's Avatar
I think we probably have a certain member of this very forum, who drives a turbo, to thank for this.....
Why can't they just be thankful that Porsche decided to build the P!g and leave it at that??
Old 05-16-2012, 02:00 PM
azzurri
azzurri's Avatar
Thanks so much for posting this. Really appreciate
Old 05-16-2012, 06:41 PM
KevinGross
KevinGross's Avatar
Echoing others, nice write-up.
Kevin
Old 05-16-2012, 08:12 PM
Mike in CA
Mike in CA's Avatar
Kevin
You're welcome and thanks.
Old 05-18-2012, 11:13 PM
YRUNVS
YRUNVS's Avatar
Default DIY oil change
Great post and pix! Do you know if anyone has done this for the 2011-12 V6?
Old 05-19-2012, 12:47 AM
Mike in CA
Mike in CA's Avatar
Thanks. Not that I've seen....
Old 05-19-2012, 01:14 AM
Slow Guy
Slow Guy's Avatar
Might check Renntech.org for the V6.
Quick Reply: Cayenne 958 V8 DIY Oil Change w/pictures
