Brake Pad Warning light question
Old 04-09-2016, 02:14 PM
Dilberto
Dilberto's Avatar
FYI - one the warning lamp stays ON.....you can "effectively" squeeze in another 2300 miles
Old 05-19-2016, 05:16 PM
Earthen
4th Gear
Earthen's Avatar
HI I'm new to this thread. I found this forum while back while looking for a fix to this same problem. I found my solution so I thought I come back and share it for others since I see no one has posted the solution that I've found.
anyway it was a very simple fix for me all I had to do was clean the to metal prongs inside the connector (Porsche side) where your new break sensors plug. mine had gotten a little corrosion on them and I guess it was enough to break the connection. I just wrapped a bit of fine emery cloth around a small flat screwdriver to clean it. Then when I plugged it in, poof! no more break pad symbol on startup
hope this helps someone from pulling as much hair out as I did!
Scotty_G (02-04-2022)
Old 08-09-2018, 12:31 AM
coloradocayenne4
coloradocayenne4's Avatar
I replaced my pads today they were not worn out just badly glazed and grooved as were the rotors, I replaced pads and rotors and reused the sensors , I pulled them out of the pads carefully and intact, but after doing the brakes the brake likgt go to workshop comes on.
Old 08-09-2018, 03:05 AM
mudman2
Moderator !x4
mudman2's Avatar
You saved yourself 20 bucks but now have to do it again. The wear sensors are delicate as you saw , one broke replace both
Old 08-09-2018, 01:12 PM
nodoors
nodoors's Avatar
Quickest fix:
Unplug each and test for continuity with a multimeter. When you find the one that is open, just clip it on the brake pad side of the harness and short the wires using your method of choice.
Old 08-09-2018, 01:15 PM
mudman2
Moderator !x4
mudman2's Avatar
Originally Posted by nodoors
Quickest fix:
true but then they no longer work. May not be important to you
Old 08-09-2018, 02:53 PM
nodoors
nodoors's Avatar
Not a concern at all. I have a number of vehicles that never came with pad sensors or screechers on the pads and it is a nonissue in my opinion.
I like to change my pads the same way I use the brakes! Late and full pressure!
The pad sensors come on way too early for my taste, and one will give you plenty of time. If they are so out of balance that one sensor does not catch both sides, you are likely due for some major brake work anyways and scraping up the rotor is a non-issue.
Old 10-14-2020, 09:49 PM
dlbehrns
dlbehrns's Avatar
Here we go again, same problem with a little more drama. replaced pads w/ceramic Hawks. sensors also and resurfaced the rotors. the Hawk pads suck. Noisy and dusty and loss of the great sensitive feel of oem pads. I did my homework and thought I made a good choice. NOT. The brake pad warning light will not go out AND a panic stop will not kick in the ABS. HELP!
Old 10-15-2020, 03:27 PM
Petrolhead_007
Petrolhead_007's Avatar
well you answered your own question- loss of oem brake feel since you switched to hawk pads. Put OEM Pagid brake pads with new sensors. Also check to see if the rotors are still above min thickness.
Probably a good idea to replace brake fluid at the same time if it's due.
Old 10-15-2020, 06:54 PM
dlbehrns
dlbehrns's Avatar
forgot to mention I did the bfluid too. Thanks for the tip
Old 10-15-2020, 09:56 PM
dlbehrns
dlbehrns's Avatar
the main reason I went with hawk ceramic was to reduce brake dust and, I was told by the sales person I would not lose brake feel. wasn't the first time I was lied to. Is this what you were talking about? https://www.ebay.com/itm/Hella-PAGID-355013801-Front-Disc-Brake-Pad-Set-for-Porsche-Boxster-Cayman/363092413193?epid=194878832&hash=item5489fe8b09:gosAAOSwibJfTjcA
Old 10-15-2020, 10:31 PM
dlbehrns
dlbehrns's Avatar
Does anyone have any experience with Brembo? TIA
https://www.ebay.com/itm/For-Porsche...kAAOSwvcFb~Xoq
Old 10-16-2020, 09:58 PM
dlbehrns
dlbehrns's Avatar
anybody?
Old 10-17-2020, 05:44 AM
Harry Apps
Harry Apps's Avatar
anybody?
I replaced my 2010 957 GTS rear pads 5 months ago - no problems whatsoever. Brembo would usually be my first choice for brake parts when needed.
Old 02-04-2022, 04:13 PM
Scotty_G
2nd Gear
Scotty_G's Avatar
Thanks, Earthen! My brake pad light came on a couple of days ago even though my brake pads are still almost new. I'll give that a shot, thanks!
Quick Reply: Brake Pad Warning light question
