Snows:DoI need them?
The Iceland Blue **** came with new AVID envigor's by Yokohama unidirectional M+S and a set of Dunlop GRANTREK snows. Live in Columbus Ohio. I have way to many wheels and tires! Do I need them?
Rocky Mountain High
I think winter tires make a big difference, not only in snow but in cold weather on dry or wet roads. I'd keep them if I were you.
Super Moderator
Needs More Cowbell
Needs More Cowbell
It's all about the tire compounds.
If you don't have "snowflake" sidewall tires, you will be driving on hockey pucks when it gets cold.
Of course, I won't shed a tear over another Cayenne being wrecked ...
All Season
When I ordered my '11 CS I checked the "all season" which has been described as "no season" - and rightly so.
I drove through some winter after my pick up in Feb.
Wanting to drive to Colorado I just installed a set of Blizzaks w/ 18" 5 spoke take offs from Alex @ the Tire Rack.
What a great investment. We are in Colorado for Thanksgiving and had a chance to compare. Turning and stopping are the most obvious improvement to me. Not any deep snow to see the traction change.
I have found wheels and tire are only expensive when you are buying - very poor resale - so you may as well keep them!
None of my vehicles run on anything but summer use tires, ever!!
Heavily siped tires, M+S, All Season, wintertime specialty tires, are an advantage ONLY when they can sink into the surface, mud, snow, slush, etc. 99.99% of the time the larger contact surface area of summer use only tires will outperform ANY wintertime specialty tire.
So for that .01% time I have a set of tire chains on board...ALWAYS. Two sets during the winter season. Rear set goes on first, even on F/awd RX300, fronts additional only when needed.
Super Moderator
Needs More Cowbell
Needs More Cowbell
It's so obvious now...
Rocky Mountain High
Take a look at this video from www.tirerack.com and you'll see the difference on the hard frozen surface of an ice rink.
http://www.tirerack.com/videos/index...=26&tab=winter
Very good link, Dennis. Thanks....
