2008-How do I disable TPMS?
My new set of rims are pre-2008's and don't have sensors. Can I disable the TPMS in my car? I believe the answer is no. Will the dealer disable? I have access to an autologic if someone can explain what exactly needs to be done. I hear you need to pull the fuse and then recode to remove?
The V8 Porschephile
You cannot self-disable the TPMS system for obvious reasons. However, the dealer can in fact do this procedure using the PIWIS yet I would be very surprised if they would; given the potential liability issues. It never hurts to ask.
