DIY Oil change for 2009 GTS
Old 12-28-2010, 08:06 AM
Javaduck2
5th Gear
Javaduck2's Avatar
Default DIY Oil change for 2009 GTS
Anyone have instructions on DIY oil change for 2009 Cayenne GTS??
Old 12-28-2010, 11:35 AM
k722070
k722070's Avatar
DUTCH posted instructions on renntech.org for a transsyberia, same process for gts.
Old 12-30-2010, 07:27 AM
Javaduck2
5th Gear
Javaduck2's Avatar
Thanks!! Cant find it..u have a link you can post??
Old 12-30-2010, 11:04 AM
k722070
k722070's Avatar
it might be a 2 step process for you
http://www.renntech.org/forums/index.php?app=donate
then you'll be able to view the maintenance thread
http://www.renntech.org/forums/index...e-maintenance/
Old 07-18-2018, 06:03 PM
redstack
redstack's Avatar
Yea, I just came in to check on how many oil drain plugs my 08 GTS is supposed to have. i thought two, but it's only one. The rennetech post was helpful
Old 07-19-2018, 08:43 AM
the flyin' scotsman
the flyin' scotsman's Avatar
1 8mm hex drain plug and 36mm oil filter housing. Use a new washer on the drain plug and new Oring on filter housing.
Takes longer to remove and re-install the under engine covers.
Old 07-19-2018, 06:04 PM
redstack
redstack's Avatar
True dat, took me for ever to find all the fasteners. I didn't pull the back shield because I was working under the truck raised to special height. I figured that by pulling the leading edge down just a little, I could have a clear shot at the drain pan. Of course the hot oil made me flinch which let a jet shoot out of the cover and right into my lap. Oh well. The filter cover I bought the shallow dish 36mm socket off Amazon for $9, very worth it. Couldn't fit my big torque wrench on the filter when going back in, so just took it really easy. One trick I used was to push both ends of the new filter onto the housing before installing, so the filter will fit easily over the internal raised center of the filter housing.
Old 07-20-2018, 08:33 PM
the flyin' scotsman
Use a piece of bent cardboard under the drain so you dont have to remove the rear shield or worry about the splash effect.
I also have a shallow 36mm socket which I consider a must.
Agree with installing filter firmly in housing after a good cleaning then re-install on engine.
Quick Reply: DIY Oil change for 2009 GTS
