Cayenne loss of controls on steering wheel
Hi,
I have an issue with my Cayenne where all the controls on the steering wheel and column are not working - ie radio, tipronic,indicators,wipers etc. On the dash the radio and emergency indicators all work fine. Hopefully someone can advise me of a solution Thanks Darren |
Dashboard Fusebox, Left Side: Check fuses 8 (30A), 33 (15A), 44 (30A) & 53 (5A)
If you've had anything 'aftermarket' recently installed on the vehicle, there may be a correlation between it and the problems that you're experiencing. |
Everything you mentioned is on the CAN bus so fuse a good maybe
Can you explain a little further- what do you mean by Can Bus?
What did the problem end up being? I'm having the exact same issue with my 2006 cayenne.
Any results as I have no steering wheel (i.e no tiptronic, radio or mute) buttons or lights to the steering wheel. All fuses are good. Is there a module that controls these wheel buttons? 2003 Cayenne S Tip
Wow no reply on this
Originally Posted by Pkcayenne
(Post 14403320)
Thanks Don sorry for my Wow will make a new post
CAN Bus failure check fuses
Can bus failure
Hi mudman
are you suggesting all fuses failed ?
Originally Posted by mudman2
(Post 14403471)
Anybody know where the fuse for the steering column switch is on the cayenne 04 tt
Mudman all checked all the fuses is there a switch which controls all the lights on the steering wheel plus the telescopic controls tiptromic padels
Still fighting with this issues
Still fighting with this 3 months and going thinking to disconnect the canbus or radio any ideas
I had a problem like this when I installed a generic control module for one of my truck's Xenon headlamps. The headlamp worked fine, but for whatever reason the controller caused the steering wheel controls and PCM to shut down from time to time. Switching to the right factory headlamp controller cleared the problem (and my wallet). So consistent with others' mention of CAN bus failures. Good luck!
