Cayenne Engine Replacement
#166
Former Vendor
Ours won't work for that application. I altered the running clearances and do not use Porsche journal diameters. We have intended to only utilize these in our engines, not selling any parts.
The dealer can get you the right bearings.. But they are only available in standard sizing.
#171
Former Vendor
#172
Question for Flat6 Innovations:
Have you used piston oil squirters from 2007 M48.01/51 motors as an update to the 4.5L block? I thought I heard somewhere this is a viable update. Wondering if anyone has any experience actually doing this and if the parts 'bolt' in?
Thought I read it in the workshop manual as an update during a rebuild.
Curious of your thoughts anyway.
Thanks!
Jonathon
Thanks!
Jonathon
#173
Thanks!
Jonathon
Thanks!
Jonathon
#174
If you have an 04-06 s then you can just use the 04 to 06 squirters and just bolt them in. They are calibrated to open at a specific pressure so that your main and rod bearings get pressure first at start up. The 4.8 has a different oiling system and clearances.
#177
Former Vendor
#179
