Known Cayenne drivetrain problems?
#31
May need to PM him directly as this thread is 4yrs old. And by Drivetrain I assume you mean the Driveshaft? The rubber portion of the Center Support Bearing tends to go. Also if you post your location in your signature line on the left it will be easier for others in your area to help you.
#32
If it is the drive shaft (cardan shaft), it's a cheap, fast, and easy repair. If you can wrench at all, you can do it yourself. If you have an indy who'll work with you and install a rebuilt shaft, you're looking at $600-$700 total. If you go to Porsche, well, it's gonna be more...
#33
Question on Vertex Clamping Support in lieu of shaft replacement?
http://www.vertexauto.com/ShowItem/2...t%20Mount.aspx
#35
