Dumb Brake Pad Question
I am going to replace the pads (F and R) on my 05 CTT. I was looking around for pads and saw that some are for 17", 18" and 19". My car was purchased recently and the PO put 22 inch rims so I do not know what the stock rim size was.
I thought that all the brakes were the same on CTT's so I am very confused now. Can anybody point out what I am missing and also what pads to use.
Thanks,
Steve
Thanks,
Steve
Thanks,
Steve
Thanks,
Steve
http://e-partssales.com/Merchant2/me...de=955ttbrakes
Also, do a search on rear brakes. You need a special tool for the rear, I don't remember the exact size but it was a pretty big triple square bit.
Rocky Mountain High
Moderator !x4
OK 2 tips
1 - go to Sears Hardware and buy a decent punch set, they come in 3's
2 - When you have the pin out, use emory paper or sand paper to clean the accumulated dust build up, when you put it back in it really makes it easier to get over the spring, which you can also compress using a screwdriver to hold it in position until the pin pushes the driver out of the way.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I was playing around on ebay looking at pads and saw that some of the listings were for 17",18"...
I think started looking elsewhere and saw the same thing. I know that ebay is not the best source of info however I wanted to find out the real situation.
Thanks everyone for the info.
Steve
Steve
