Couple of weird CTT issues today
Brought my car in today for 3 things.
1. Brake pad replacement.
2. Battery wasn't holding a charge well after a few days of non-use...which is not surprising with 3+ years on the same battery.
3. As I pulled into the dealer, I got a weird warning light on the display. I believe it read "Oil Measurement System Failure - Workshop." Not that this is different than the check oil light.
The staff took care of items one and two, but saw no warning light when they started it up. It was a quart low so they added oil.
Anyway...on the way home I experienced two weird things.
First, that same warning came up, intermittently. When it did come on, the Oil Temperature Gauge went to zero and stayed there. Then it went off, I got a normal oil temp reading.
Second...the scarier one, is that under heavy acceleration, ie: stomping on it at 2500-3000rpm, the car seems to now "shutter." It's a really weird feeling. Almost like a cylinder is missing, or bad gas, or, if it were a manual - a clutch slipping. I've got no idea what's causing that, but I know for sure it wasn't like that when I brought it in - because when I dropped it off, the service tech drove me back to a local hotel where I was having a meeting...and as we headed across two lanes of traffic to make a U-Turn, I stomped on it and pinned us both back in our seats as usual.
Any ideas???? Could it be related to a power short when they replaced the battery??
Regards
Steve
Regards
Steve
Pepper Bartender
Regards
Steve
Regards
Steve
2004 CTT....72K miles or so... Definitely not gas, since the problem didn't exist on the way to the dealer.
Also, need to find out about this other oil sensor...where it is and how to fix it.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Vibration from the cardan shaft caused premature failure of the coolant tubes which broke, were ingested into the engine and now the engine is done, finished, adios.
Happens all the time
Pepper Bartender
Looks like the hesitation issue was solved by using the "turn the key for 60 seconds with your foot off the brake" method to reset the onboard computer and adaptive transmission. Must have garbled when they pulled the battery.
God you guys are so quick to push cars off a cliff )
Anyway...still have this odd oil sensor issue. Any ideas on that would be very, very welcome.
Regards
Steve
Regards
Steve
Moderator !x4
Steve
You are so wrong, that method resets E-Gas only, you will learn to live with the hesitation and use the thumbs when you need to
Dealer will need to hook up the tester to read any error codes for the oil sensor
Mike
Mike
That's incorrect... I've used that method for all sorts of things when everything else has failed. For example, a frozen PCM that won't turn on. Tried everything including pulling the fuse itself. The only thing that worked was the key reset
Pepper Bartender
but, if it works for you..................
