Shuddering at low speeds/high gear
I have a 06 S, bought new. Now with 5K miles, and it has had an annoying problem for most of its life. When between 30- 40 mph in 4, 5 or 6th gear, light accleration will cause the vehicle to shudder. Goes away when you stomp on the gas. No fault codes or warning lights appear
No problem in 1-3 gear at any speed Have been to 2 dealers multiple times, coils replaced with latest parts, DME flashed etc. No change. Discussed with Porsche NA, not getting very far I have searched this forum and others, cannot get a handle on what is the issue might be. Please offer any constructive advice, as i am at my wits end:banghead: |
So, you are saying it is NOT RPM specific but rather SPEED specific?
(so 30-40 in 4,5,6....tiptronic manual mode I'm assuming...and it does it)? I'm assuming normal water temperatures? Try turning PSM OFF and see if that changes anything. Doesn't sound like a cardan shaft.....I'm guessing tran$mi$$ion......or perhaps motor mount(s). Oh wait, you said "constructive advice".....that rules me out.....forget everything I typed....where is the 'delete' key? |
Sounds very similar to what I experienced on our 04 S. It turned out to be a failed driveshaft center bearing. which involved replacing the drive shaft.
mine did not only do it under light acceleration, but the whole car was shuddering. quite excessively at times. |
See my post in the thread "Coils TSB" at the top of teh page. Read my scanned invoices where I had my '04 "S" in for that VERY exact same thing. You can actually read where they typed in my complaint and it is almost identical to yours. They (amongst other things) did the coil pack replacements, BUT they also did a Transmission ECU "upgrade" or something like that? All I know is that it is NO LONGER shifting like that, so......
Jason |
Originally Posted by Nexus 6
(Post 4710976)
Jason |
Originally Posted by JRCTT
(Post 4711054)
Did they list any information on the transmission ECU "upgrade" on your invoice? I asked my service writer to have the version on mine checked and was told I had the right version but I am not convinced they actually checked it :rolleyes: ...thx
All I know is...you can see my chief complaint was my transmission was shifting erratically and that seemed to have fixed it as it has now been a couple of weeks and I am good to go. My problem I told them was: "Between speeds of 20-30, and when I am not in Tiptronic mode, I go to accelerate....it was most common and noticeable when exiting the freeway when I would go home from work. The exit had a huge loop, and as I would exit I would let off the gas, enter the turn, and slowly go to accelerate and the trans would STILL have me in 6th gear. As I slowly applied gas...the car would shudder as it tried to accelerate from 6th gear at a low speed. Then I even noticed it in high traffic conditions on the freeway...again at that 20-30MPH range" Thats pretty much how I described it for them. And what you see on the invoice is how they wrote it down. They performed the services you see listed, and I am now good to go. Hope that helped? Jason |
My '06 does that too. The car is too new to have coil problems. I think it's "normal".
Originally Posted by racer_65
(Post 4711467)
My '06 does that too. The car is too new to have coil problems..
(Post 4711467)
Originally Posted by ltc
(Post 4711858)
Wrong
If that is your definition of 'Normal', then if you say so. |
(Post 4712994)
The car is so new that everything should be very close to factory spec. Once you have a mechanic work on it, you never know what could happen.
Originally Posted by JFScheck
(Post 4713056)
You must be new to Porsches... :burnout:
I thought the EXACT same thing because mine had a CLEAN CARFAX, only one previous owner...and it is a 2004 that had 17k miles on it!! And I STILL had the problems that most others have had, some new and some old. I would get it checked out myself? Why wait and ASSUME (ASS/U/ME) that it is normal? Dude...I am going to tell you...THAT is NOT normal. |
Well, 2004 car is a different story...
I will check the ECU upgrade on my invoice
Thanks for the advice |
BEWARE
the transmission flash was what started my "PHC unavailable" saga.
some of these cars aren't even compatible with themselves, expecting mechanics to determine the "upgradability" of the units and the "current available" firmware is silly. but they try anyway.... |
Sounds like carrier bearing on drive shaft, you will feel the vibration throughout the vehicle. Double check your receipt for your coils and verify you got pn's ending in 03
MArk |
