Cost of 20K check up...
Timely thread - mine is going in tomorrow, and the b*tch of it is that I just got a free oil change as part of the inspection for an ext warranty- but at another shop. So I'll be dumping my new oil so the dealer can charge me 250 bucks for the same stuff.
Hell, they'll probably just dump it from the drain pan back into my crankcase.
Mine was about $670, including 10% off PCA membership discount. Most dealers will try to throw in things like replacing wiper blades and want to charge you $100 for that. Tell them to stick with what's in the Manual, and do the blades yourself for half the cost.
Labor rates can be a big variable on the cost, with large metro areas (like LA) usually charging a good bit more per hour. My dealer in N. Va. is at $118/hour right now. Top independent shops are around $90-95 per hour in this area.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Important Notes:
· The engine oil and oil filter must be changed every 6,000 miles (10,000 km) in vehicles which are operated in countries where leaded fuel is used.
· If the mileage for a regular service is not reached, minor maintenance must be carried out after 2, 6, 10...... years.
· The term "checking" includes all necessary subsequent work such as adjusting, readjusting, correcting and topping up, but does not include repairing, replacing and reconditioning parts or assemblies!
· The maintenance item Replacing spark plugs depends on the engine type.
Bastards told me that Brake fluid flush was required.
In total they charged me $741. this included $7 for washer fluid that I had just topped off. They insisted it was low.
Needless to say I will be using a different dealership next service.
