Looking to buy Cayenne...need some advice.
I have an '05 CS and I love it. No issues at all w/ 7k miles and 5 mos under my belt. While it has been a bit difficult going from an Audi S8 to this, I have absolutely no regrets. My guess is that is you go with an '05 or later, you'll have all the glitches worked out.
As for me, I'm looking to move to a Turbo...
Pepper Bartender
Originally Posted by littlejt1
Have been leaning toward the CS, but may opt for the 6 mainly for mpg reasons. I have only really run across data on the CS and turbo when it comes to fuel economy. This will likely be a daily driver (so I can turn my 951 into a track star!)...I drive my 951 almost daily now.
..still looking to see if someone on here does their own wrenching and can let me know how easy/hard simple maintenances are (oil change, plugs, etc)...I don't mind taking things to the shop if need be, but I love working on them myself as well (recently replaced the clutch in the 951 in my garage). Thanks!!!
The difference between S and V6 seems to be small in city... in city driving I average 15.8mpg.
But on an open highway with the CC set @ 75mph... I can pull 23-25mpg. The V6 wastes all it's gas getting up to speed, but maintains it nicely.
Pepper Bartender
analyst
Oil change is no problem, except resetting the service indicator requires a $12K tool that requires $5K / year support contract. Or, just pay the dealer to reset the indicator. Two drain plugs on the V8.
No problem changing the cabin air filter.
The brake fluid is changed every two years, posts to follow.
The brakes and rotors last around 25 - 30 K mikes.
Great info!! Thanks to all...
On the V6 vs V8 info...exactly what I thought as the number on paper seemed to be nearly the same. I figured the 6 labored a bit pulling the weight of the thing!!
Still not 100% sure if I'm going to buy, and it will for sure be a low mile used, with ext warranty. Going to take my time and look around for the "right" one. Just about to put the 951 in the shop for a new paint job, so when I get it out and get tired of driving it (lol yeah right...like that'll happen)...
I might look a little harder.
As usual, the Rennlist community never fails helpnig out!!
Thanks to all!!
Thanks to all!!
