Adding a rear locking diff
Old Aug 10, 2024 | 08:20 PM
bbqlord's Avatar
bbqlord
Default Adding a rear locking diff
i found a complete kit(diff, wiring and controle module) for a 957 tts that had the rear locking diff. I just bought an 09 S that doesnt have it. is it possible to install it and have it programmed into the car?
Old Aug 10, 2024 | 09:47 PM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
o,0
Old Aug 11, 2024 | 10:25 AM
19psi's Avatar
19psi
You better research differential ratios between turbo and S. If it's like the 955, there are 3 different available depending on base, S, turbo and manual vs auto trans.
Old Aug 11, 2024 | 11:48 AM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
Could this be found out with the VIN?
Old Aug 11, 2024 | 02:56 PM
19psi's Avatar
19psi
Possibly, but when I bought a front replacement I just looked up the part # for my year and model from an online vendor.
This thread may also help:
https://rennlist.com/forums/cayenne-...t-writeup.html
Old Aug 11, 2024 | 05:02 PM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
@bbqlord I will make mention there is apparently a good deal of difficulty splicimg in the necessary harness connections. I looked into this a bit as well.
Old Aug 11, 2024 | 07:53 PM
bbqlord's Avatar
bbqlord
thanks ill look into this. the seller doesn not have the truck anymore so i is the part number written somewhere on the part so i can verify?
so i understand its "doable" with the right amount of money and time to figure it out lol.
