Need help choosing first cayenne
Im considering buying a cayenne soon. i did some research and i narrowed it down quite a bit. i want a 957. im too poor to buy a gts or maintain a turbo. so im hesitating between the 3.6 and 4.8. but the cylinder scoring horror stories of the 4.8 is scaring me but i want the HP. Does the cylinder scoring applies to the 4.8 too or was mainly a 4.5 problem? and since bad lubrication would worsen the problem, is buying a very low miles exemple a bad idea? since it could lack lubrication and oil pressure if it sat for a long time between each use? anything else i should watch for like known problems or rare/nice specs? and for the people who have the 3.6, do you think it lacks power?
However, your statement of being too poor makes me question your ability to afford the platform (no offense intended). Are you doing all the maintenance and repairs yourself or would you use a mechanic? If you aren’t fixing it yourself, any Cayenne out of warranty is a bad idea. Also, the turbo models aren’t any less reliable than the non-turbo ones.
The following 2 users liked this post by BobcatBrian:
SuperG$ (04-26-2024),
theworkerbee (04-25-2024)
I wouldn't worry too much about one with low mileage that sits. I bought my 09 in 2016 with 28k miles on it and now it has 52k it's sat for 8 months between uses before and it's flawless mechanically. Every tank gets fuel stabilizer since I never know how long it will be before I use a full tank, and it stays on a battery tender.
If you look for a 2009, or even better, a 2010 V8, then you’ll be fine. Those should not have bore scoring issues.
Thanks for the info. and, im kidding about being poor. im not rich by any means, but im a car guy. I already own a b8 s4 audi and a b8 a4 avant. i want something to go offroading/camping with. im looking at the v8s because the v6 seems really underpowered. and the turbo is stressing me out like any other TT engine. theres a lot more to go wrong on a TT car since it has more parts to begin with. no? do people have to replace the turbos sometimes? because i dont want to have to pay for that lol. even if they are reliable, they are probably still more expensive to maintain than the regular 4.8?
It's all about the depreciation curve to me. The turbo models are just so much more car for the money vs a base or S. And no, there really isn't anything on a turbo that fails often that also doesn't fail on an S or GTS. The turbochargers, intercoolers, and piping should last the life of the car. You may need to replace the diverter valves at some point, but those are cheap and a pretty easy DIY. The only reason I wouldn't get a turbo is if you're going to trash it offroad. If you're just going to overland and camp, throw some decent trail tires on it and enjoy!
I know of at least one turbo with over 600k miles on the original engine. I would not worry about the turbochargers. On a 957 V8, I'd be more worried about the HPFP (as it's $$$). Find a car that someone else has dumped a bunch of money into and go from there. You don't need a low mileage car, but try to get one that's sorted, has records, and preferably has been with the same owner for a while.
957 is pretty robust once the known problems are sorted -- and they are perm fixes.
OP find that unicorn - 957 Turbo S with PCCB!
IMO - the 957 is proper rally car -- the 959 with rear seats.
They don't have to be replaced anymore. There are companies that will rebond a new friction layer onto the ceramic cores for reasonable money. There's a whole Facebook group for carbon ceramic brakes.
Malibu955 (04-25-2024)
just having a v8 or TT cayenne will be enough for me to start with no need to add carbon brakes in the mix haha and i dont think id see the benefit with what i want to do with it.
BobcatBrian (04-26-2024)
