2005 cayenne s
6th Gear
2005 cayenne s
Hi all. I bought a 2005 Porsche cayenne s about 6 months ago. It's been a great car. But I'm having some trouble with the abs. My abs light is on. The pads and rotors were changed before I bought the car. Today I decided to try to figure out the issue. I removed all the sensors inspected them and cleaned them and then cleaned their holes out reinstalled. Checked with a scan tool and all sensors are reading. I have a good solid brake pedal. I have read on this forum that the abs module could be the problem. I'm not sure and could use a little guidance from someone that had a issue like this thanks Porsche community
You need to read the fault codes.
When does the error first appear, like is it when you turn sharply at low speed, high speed, comes on immediately as soon as the car is started, etc?
6th Gear
Right at start up. When I start the car I get psm fault workshop and abs fault workshop. Along with brake pads work shop. The pads and rotors are new all around. Yesterday I cleaned all the sensors and their mounts. And I recently replaced the front driver hub. The abs light has been on since I bought the car about 6 months ago. The code is 1276.
Based on the timeline of when errors first occur, and the servicing of the system, all your parts seem new, I'd start to think it could be the main unit possibly (abs module)? Maybe using a Durametric tool might give you more insight, not 100% though. I too have an 05' S so I'm watching for my own reference down the road as well.
Marshal c (04-23-2024)
1276 is a problem with the return pump, most likely a burned out transistor in the ABS module. There is a company "module master" that can repair these ABS modules or you can get a used ABS unit & install it. If you go used match the Bosch part# printed on the black ABS module which you need a mirror to see. Don't worry so much about the engraved numbers on the aluminum casting.
6th Gear
6th Gear
545moose (04-25-2024)
