Knock sensor alternatives in a pinch
12-15-2023, 06:13 PM
Cruisin'
I'm in a bit of a bind with my '04 Turbo . While changing out the large coolant pipe under the manifold, I must have damaged the knock sensor that sits under it (the symptoms and ecu codes point to that fact, along with the fact that I did physically damage the plug-area of the sensor's casing). I've ordered a replacement but really need to drive again before it will arrive . Assuming there's chance one of my local autoparts stores will have a random assortment of Bosch sensors... my question is whether there are other 2-pin Bosch sensors that will send the signal my Cayenne's ECU is looking for .
Thanks in advance for the insights.
Spence
12-15-2023, 06:34 PM
Cruisin'
it looks like Porsche used the same sensor for all their models between about 1999-2005, so it can't be too specific (dependent on bore size, etc).
12-15-2023, 06:38 PM
Check with rock auto and see what they offer. I found this on Amazon and I can get it next day:
12-15-2023, 07:18 PM
What part of the world are you in? I have some extras in central Massachusetts.
12-15-2023, 07:49 PM
Quote:
Originally Posted by
spencercanon
Make Model Year Range Description Position Drive Wheel Veh. Qty. Engine Base Engine VIN Engine Desg.
Alfa Romeo 4C 2015-2020 Ignition Knock (Detonation) Sensor 1 1.7L L4 1742cc
Dodge Dart 2013-2016 Ignition Knock (Detonation) Sensor 1 1.4L L4 1368cc/83cid
Fiat 124 Spider 2017-2020 Ignition Knock (Detonation) Sensor 1 1.4L L4 1368cc/83cid
Fiat 500 2012-2019 Ignition Knock (Detonation) Sensor 1 1.4L L4 1368cc/83cid
Fiat 500L 2014-2020 Ignition Knock (Detonation) Sensor 1 1.4L L4 1368cc/83cid
Fiat 500X 2016-2018 Ignition Knock (Detonation) Sensor 1 1.4L L4 1368cc/83cid
Jaguar E-Pace 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Jaguar F-Pace 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Jaguar F-Type 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Jaguar XE 2020-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Jaguar XE 2018-2019 Ignition Knock (Detonation) Sensor 1 2.0L L4 1999cc/122cid
Jaguar XF 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Jeep Renegade 2015-2018 Ignition Knock (Detonation) Sensor 1 1.4L L4 1368cc/83cid
Land Rover Discovery Sport 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Land Rover Range Rover 2020-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Land Rover Range Rover Evoque 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Land Rover Range Rover Sport 2019-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Land Rover Range Rover Velar 2018-2020 Ignition Knock (Detonation) Sensor 1 2.0L L4 1997cc/122cid
Porsche 718 Boxster 2017-2020 Ignition Knock (Detonation) Sensor 2 2.0L H4 1988cc/121cid
Porsche 718 Boxster 2017-2020 Ignition Knock (Detonation) Sensor 2 2.5L H4 2497cc/152cid
Porsche 718 Cayman 2017-2020 Ignition Knock (Detonation) Sensor 2 2.5L H4 2497cc/152cid
Porsche 718 Cayman 2017-2020 Ignition Knock (Detonation) Sensor 2 2.0L H4 1988cc/121cid
Porsche 911 2016-2019 Ignition Knock (Detonation) Sensor 2 4.0L H6 3996cc
Porsche 911 2002-2009 Ignition Knock (Detonation) Sensor 2 3.6L H6 3596cc
Porsche 911 2001-2005 Ignition Knock (Detonation) Sensor 2 3.6L H6 3606cc
Porsche 911 1999-2001 Ignition Knock (Detonation) Sensor 2 3.4L H6 3400cc
Porsche 911 2005-2013 Ignition Knock (Detonation) Sensor 2 3.8L H6 3824cc
Porsche 911 2009-2012 Ignition Knock (Detonation) Sensor 2 3.6L H6 3614cc
Porsche 911 2007-2008 Ignition Knock (Detonation) Sensor 2 3.6L H6 3598cc
Porsche 911 2012-2016 Ignition Knock (Detonation) Sensor 2 3.4L H6 3436cc
Porsche 911 2009-2019 Ignition Knock (Detonation) Sensor 2 3.8L H6 3800cc
Porsche 911 2011-2011 Ignition Knock (Detonation) Sensor 2 4.0L H6 3996cc
Porsche 911 2017-2021 Ignition Knock (Detonation) Sensor 2 3.0L H6 2981cc
Porsche 918 Spyder 2015-2015 Ignition Knock (Detonation) Sensor 4 4.6L V8 4593cc
Porsche Boxster 2000-2008 Ignition Knock (Detonation) Sensor 2 2.7L H6 2687cc
Porsche Boxster 2007-2010 Ignition Knock (Detonation) Sensor 2 3.4L H6 3387cc
Porsche Boxster 2006-2006 Ignition Knock (Detonation) Sensor 2 3.2L H6 3179cc
Porsche Boxster 1997-1999 Ignition Knock (Detonation) Sensor 2 2.5L H6 2480cc
Porsche Boxster 2011-2016 Ignition Knock (Detonation) Sensor 2 3.4L H6 3436cc
Porsche Boxster 2016-2016 Ignition Knock (Detonation) Sensor 2 3.8L H6 3800cc
Porsche Boxster 2013-2016 Ignition Knock (Detonation) Sensor 2 2.7L H6 2706cc/165cid
Porsche Boxster 2009-2012 Ignition Knock (Detonation) Sensor 2 2.9L H6 2893cc
Porsche Boxster 2000-2005 Ignition Knock (Detonation) Sensor 2 3.2L H6 3179cc
Porsche Carrera GT 2004-2005 Ignition Knock (Detonation) Sensor 4 5.7L V10 5733cc/348cid
Porsche Cayenne 2015-2018 Ignition Knock (Detonation) Sensor 2 3.6L V6 3605cc/220cid
Porsche Cayenne 2003-2006 Ignition Knock (Detonation) Sensor 2 4.5L V8 4511cc
Porsche Cayenne 2008-2018 Ignition Knock (Detonation) Sensor 4 4.8L V8 4806cc
Porsche Cayman 2006-2012 Ignition Knock (Detonation) Sensor 2 3.4L H6 3387cc
Porsche Cayman 2007-2008 Ignition Knock (Detonation) Sensor 2 2.7L H6 2687cc
Porsche Cayman 2014-2016 Ignition Knock (Detonation) Sensor 2 2.7L H6 2706cc/165cid
Porsche Cayman 2009-2012 Ignition Knock (Detonation) Sensor 2 2.9L H6 2893cc
Porsche Cayman 2014-2016 Ignition Knock (Detonation) Sensor 2 3.4L H6 3436cc
Porsche Cayman 2016-2016 Ignition Knock (Detonation) Sensor 2 3.8L H6 3800cc
Porsche Macan 2015-2018 Ignition Knock (Detonation) Sensor 2 3.0L V6 2997cc/183cid
Porsche Macan 2015-2018 Ignition Knock (Detonation) Sensor 2 3.6L V6 3605cc/220cid
Porsche Panamera 2014-2016 Ignition Knock (Detonation) Sensor 2 3.0L V6 2997cc/183cid
Porsche Panamera 2011-2016 Ignition Knock (Detonation) Sensor 2 3.6L V6 3605cc/220cid
Porsche Panamera 2010-2016 Ignition Knock (Detonation) Sensor 4 4.8L V8 4806cc
12-15-2023, 08:20 PM
Cruisin'
This is exactly the kind of cross reference I was hoping to find. Thanks!
12-15-2023, 08:22 PM
Cruisin'
theprf
I'm in the Eastern Sierra in California. One-day Amazon often literally takes 5 days.
