Faulty Air suspesion, Just drop it???
So this TTS i just picked up has the faulty suspension error. the rear is slightly higher than the front, while im figuring it out. is is possible some how to just fully lower it?? so at least it looks even?(while still being driveable)
That’s weird. Do you have the door closed? Does your air pump have enough pressure to air up a tire with the hose? Have you checked all of the ride height sensors to make sure the linkage is secure? It sounds like you may have an issue with the valve at the pump. There is also a module in the trunk just behind the right rear tire.
But is it possible to some how depressurize the system so that all 4 wheels level out? and is it drivable like that? (as I know from previous BMW experience that car is completely bottomed out)
I would guess you have a faulty air valve on one of your struts. Replace all 4, and that should fix it. Fairly easy DIY for the fronts, if you have a jack. The rears are more challenging with the strut attached, but still doable with some finesse.
No need to get OEM. I’m using a set of 4 from Amazon for around $40 total, and they all work perfectly.
Hope this helps
Hope this helps
545moose (04-17-2024)
Ride height is a dynamic system, that cannot be disabled.
The strut valves would have to be disconnected.
As PourBoi-Jay mentioned above, based on the work involved to do that you would be better off replacing them..
There is about a 40-60 Amp fuse under the drivers seat that is used for the pump. If you disconnect your lines at the pump it may drop it, but you do not want to drive it like that. You will break something else that will be more expensive than fixing the air suspension.
Ok, can anyone clarify what items would make the system, say "unable" or stop the pump from turning on? just trying to determine if the issue is at the struts or on the pump side
The only time I have seen that message is when the door is open. If you get the red warning that will not go away, it is most likely the pump. If the pump does not run then it is the pump or the fuse. If your air valves are messed up the pump will still run briefly.
Would that have anything to do with why it doesnt level? (in my mercedes, you get out of the car and you can hear the system blow off air)
Several other questions. Can I test or release pressure with the air valve under the pas seat?
How do I put it in service mode to jack it up with the error?
If I pull the pump off to rebuild it, what happens to the suspension, will it be movable (drive it to park it elsewhere)?
If you pull the air lines on the pump assembly valve block the car will drop as low as it can go. Doing so does not make the car inoperable but it is highly recommended not to drive it. I was hardheaded too and did everything possible to make mine work including rebuild of the pump, junkyard pump, replaced the valve body, new module from donor, junkyard electric motor, but nothing fixed it until I bought a new pump and motor from Europarts. I have not had another problem since.
Ok, just barely had a chance to touch it, had to put a new battery in so, so i couldn't move it till now.
I checked the valve under the Pass Seat and it barely had any pressure, but the rear wheel is still up, and front down. does that give any further clue?
