PCCM+ for First Gen Cayenne
Old Dec 14, 2022 | 04:47 PM
  #31
pnw_mike's Avatar
pnw_mike
I was shocked to hear that my local Dealership in Bellevue just got one in stock today when I called to inquire after my PCM died over the weekend. I picked it up anticipating a simple plug and play install. After opening up the box It doesn’t seem super difficult but it’s not that simple either. Has anyone installed one of these? Is there a DIY out there?
Update: It is basically plug and play, if you take a close look at the back every plug has a specific slot, there isn't much to mix up.
My only issue was that it was very quiet and only playing sound through one speaker when I first turned the system on.
This is because by default it's not set up for the Bose amp, under the "car" settings there is a selection to auto detect your cars features. This still didn't change anything even after it said "amp detected". Following this I selected "factory reset" and now it sounds great! Hopefully this helps the next guy fumbling through this without any supplied install guide.
Old Dec 14, 2022 | 11:52 PM
  #32
Malibu955's Avatar
Malibu955
Pics of it installed please!
Do you recall if there were any RCA outputs on the back of the unit? I'm guessing not since it's set up for MOST and the Bose amp. How about a rear USB port for CarPlay?
Old Dec 15, 2022 | 11:52 AM
  #33
PourBoi-Jay's Avatar
PourBoi-Jay
This seems wildly overpriced for something with relatively antiquated features. No wireless CarPlay!? Really!?
Maybe I missed it, but no mention of additions RCA outputs, added EQ settings, etc.
The only major benefit (to some) would be maintaining the radio & Nav info in the top part of the Speedo display. Other setups I’ve recently researched don’t appear to do that, but so what?
I think the Porsche tax is a bit too hefty on this one. A Dynavin N8 is a far better choice (if you can get over the looks)…..or there’s always the Android Unite which all seem to work fine with a MOST adapter/decoder
Bad value here
Old Dec 15, 2022 | 02:17 PM
  #34
slavie's Avatar
slavie
Bad value here
Ya. Welcome to the Porsche world, where occasionally parts are a tad on the pricey side.
Old Dec 15, 2022 | 02:24 PM
  #35
PourBoi-Jay
I’m all for paying the Porsche tax when it’s worth it (exclusive OEM+ options are always a winner for me), but I can’t wrap my head around spending so much on something that’s already pretty outdated.
/rant…..sorry OP
Old Dec 15, 2022 | 03:59 PM
  #36
pnw_mike's Avatar
pnw_mike
/rant…..sorry OP
But it says PORSCHE at the top.
Old Dec 15, 2022 | 05:38 PM
  #37
TomF's Avatar
TomF
Great info. Did you have to have anything programmed at the dealer?
Old Dec 15, 2022 | 05:42 PM
  #38
pnw_mike's Avatar
pnw_mike
No, after I finished the sequence I described it seems to work.
I will regretfully declare that it doesn’t sound as good as my old pcm 2.0 and it still doesn’t get very loud. Hopefully there are some more settings to sort this out.
Old Dec 15, 2022 | 07:10 PM
  #39
thesteve's Avatar
thesteve
Mine only has a CD/DVD player in that top area.
Old Dec 16, 2022 | 01:05 AM
  #40
Malibu955's Avatar
Malibu955
You may need to reconnect your PCM and set the volume to 80% or so. Also make sure that the bass and treble settings are zero and that the balance and fade are centered before disconnecting the PCM 2.0. I didn't have to do that with my Dynavin although others have had to with some of the other Android-based units, I recall reading.
Alternatively, is the volume issue on all sources or just CarPlay? You may need to turn up the volume on your phone.
Old Dec 16, 2022 | 03:30 PM
  #41
TomF's Avatar
TomF
Note Mike's update above: "This is because by default it's not set up for the Bose amp, under the "car" settings there is a selection to auto detect your cars features. This still didn't change anything even after it said "amp detected". Following this I selected "factory reset" and now it sounds great! Hopefully this helps the next guy fumbling through this without any supplied install guide."
Old Dec 16, 2022 | 05:58 PM
  #42
Crozzer's Avatar
Crozzer
I think that same Mike later replied that it does not get as loud, etc.
I’ll be eagerly waiting for others’ experiences!
and thanks for the pricing tip. I buy enough from them, I may be able to match that if I ask.
Old Dec 16, 2022 | 06:45 PM
  #43
Malibu955's Avatar
Malibu955
Yes, he then posted a later update and said it still wasn't loud enough.
Old Dec 16, 2022 | 07:11 PM
  #44
TomF's Avatar
TomF
Bummer. I guess I missed that...
Old Dec 16, 2022 | 07:34 PM
  #45
957austin's Avatar
957austin
Does this official Porsche unit use the same generic fiber optic adapter as the aftermarket units that utilize a single channel to the amplifier (i.e. it has 1 pair of RCA inputs connected to the head unit and 1 orange fiber optic output that goes to the amplifier)? If so, I think that's why the sound quality will never be as full sounding as the original PCM.
