What is the best year and model to make a safari offroader?
Hey all,
Ive been a long time lister with many models and owned a 2004 V6 when they first came out and was an awesome car. Sold in 2015 with 160K miles on it and never had the heads off. Maybe Im lucky or just a tinkerer. I live in AZ and VA, offroad in the desert, highland woods and snow in the mountains. The Cayenne is so very capable off road I am considering selling my Wrangler and build a cool offroad Porsche. It has so many options and unlike my jeep is comfortable on the highways and offroad. What are your thoughts on which model you all think would be what I should be looking for. I am not afraid of high miles. I build motors and do all myown maintenance. Open for thoughts, opionons and comic snide remarks.
Rennlist had an article on the topic which got me thinking. Looking at something like this.
Cheers, Mike
Cheers, Mike
uphoto (11-22-2022)
Really any model will work, with the caveat that the more expensive models will require more money in maintenance and have more stuff to break. I think that the 957 V6 is a sweet spot for doing an off-road build mainly because the VW power plant is just simpler than the V8s and cheaper to maintain while still providing enough power. The V6 in the 955 is similar with regard to maintenance but pretty underpowered and thus I would skip it. You can absolutely build an S or a Turbo model, but you trade cheaper maintenance and a few less things to go wrong for more power. It's a decision only you can make because there's no wrong answer, only options. That said, if this was a life or death situation crossing the Sahara I would opt for a 957 V6 with coil springs. Otherwise anything is fine. Most Turbo and GTS models have aero skirts which will decrease ground clearance a bit, but those are removable. The only option I would actively avoid would be the panoramic roof. I would be worried about cracking it.
Mud&Dirt (11-21-2022)
Search, there's lots of good info in both Gen 1 and Gen 2 forums:
https://rennlist.com/forums/cayenne-...some-help.html
https://rennlist.com/forums/cayenne-...ng-setups.html
https://rennlist.com/forums/cayenne-...ffroading.html
Cheers, Mike
Thank you, will read up - Mike
I just built one. 2003 Turbo. Learned ALOT about the Cayenne in the last 10 months. For the Safari build, Turbos have their drawbacks and few advantages, mainly being the power. 450HP feels great on 32 inch tires... But you have less wheel well to work with unless you start cutting, a lot. Or you can use smaller tires, but I wanted more rubber.
My motor mounts are gone and the only way to replace them is to drop the engine. Not easy nor cheap. The S is doable without the engine coming out, which is huge savings in labor. Did I say that the power of the turbo is great?
I have the v8 and I think it’s more than enough for a safari build. But like stated above, the v6 I think is the sweet spot. It’s not going to sound as good as the v8 but the overall reliability with them is pretty good.
so at minimum the standard cayenne and at maximum the S. The gts could be acceptable as well but the lower body bits that you’re going to get banged up or cut doesn’t justify it to me. The turbo is if you have the financial means to go about doing off road stuff and don’t care with big money repair bills.
Van Krisztian (11-24-2022)
Cheers, Mike
Cheers, Mike
