Cayenne Propshaft vibration help
I don't necessarily disagree. Jimi-fix is well proven. But I don't think it should be considered the best/only/last fix. And as is stated above, I wanted something that would be considered quality.... not that the jimi doesn't work, but I don't think it screams "quality" ???♂???♂
That said, either EPS kit or Jimi-fix only work if your existing, failure prone bearing and giubo are in good condition. If you have to replace the bearing or the guibo, you have to take out the whole shaft and it just makes sense to put in a new GKN shaft that will give you guaranteed 80-100k miles of service - more than you are likely to keep the Cayenne for in most cases. That's what happened to me - I went to put in the Jimi-fix, realized my bearing was shot, put in a new $400 GKN shaft.
Aluminum or CF shaft is, of course, the best solution if you're willing to spend the money for it.
