Complete suspension refresh
Thats as close as they could get it? don't pay for that BS, i would not.
something is seriously wrong with the passenger front caster... Camber sucks but that is an easy fix.. im amazed they sent it out like this and you paid for it!
Cw
avoid chains, dealerships are good for this and so are small ma and pa shops.
Crawling under the car, I'm gonna be honest, I don't think they touched the front camber bolts. My paint marks are still exactly where I put them.
So I guess I'll schedule with the dealer and get a front end alignment done.... can't trust anyone these days.
If you end up taking it back, I might also have them dial out some of the negative rear camber. If you have air suspension, where did you have the ride height set. I drop mine to sport because I'm over that automatic lowering speed threshold of 75 mph most of the time and don't want the lowering of the suspension to add even more negative camber while highway cruising which just wears out the insides of the tires.. If you drive under 75 MPH a lot you may want it set with about 0.5 degrees at normal ride height so it's at about what you show here if not a bit less.
either way, Setting an alignment at the dealer. Lesson learned. I just have to do a bit of driving the next week or two, before the dealer can get me in.
FRUSTRATED.
cw
I took it in with it set at normal height. When I got back in, It was set to low. Dont know if that means they took it for a drive and got it over the MPH limit? But I think it reset back to normal doesn't it?
FRUSTRATED.
cw
FRUSTRATED.
cw
Sounds like they hit the Sport button for their test drive /-:
Originally Posted by Petza914
If the car is set in normal height it will drop to sport height at 75 mph, but then return to normal height at some slower speed (like maybe 50 mph). If sport height is selected by either the sport mode button or the height toggle, it will stay at sport height even at the slower speed and even if the car goes 75 at some point end then slows back down below 50.
Yeah, I'm trying not to think about that, as it will really **** me off. All I know is that I took it in with no gas. Only 65/70 showing on the range. And it had the same when I jumped in.... but I can't do anything about it or prove anything. So I just won't go back... ???♂???♂???♂
