Trickle Charger?
Magdaddy (08-23-2022)
None that I have seen. I mostly lived in Europe from 2018 - 2021 and the Cayenne would sit for months at a time in the US with the battery disconnected, and for over a year in the case of 2020 and Covid travel restrictions. No problems whatsoever except for resetting the "Comfort" settings. I would suggest a fuel stabilizer if you're going to leave it for four months. I used STA-BIL.
JohnnyFDJ (08-24-2022)
i would say i'm very well versed in the ways of batteries and how to maintain them and how they are charged by these cars and many others. Your statement that it takes 20 minutes or whatever to charge a battery from one start up is completely old school wrong. Your post had no factual data, only old myths and old man ignorance to the workings of a multi meter and oscilloscope.
I made no claims to being an expert but i can all BS to bad info when i see it.
Deltran happens to be one of the worst on the market with whats even worse, many counterfeits nearly impossible to distinguish. they're not expensive and they're not solid state. they're cheap unreliable garbage that puts out a very bad irregular sin wave. this brand has killed the most batteries in my fleet out of them all.
When you spend about 5 grand on batteries for your sitting around stuff... you spend $$ on chargers and maintainers and dozens of hours of research and trial and error. its sad to day that i have killed about a grand in batteries from just a few weeks to only a years life using cheap chargers.
the cost to get a proper NOCO is not that much more for one or 2 chargers. Isn't this the Porsche group who want nothing but the best?!
Unless you have a very expensive modified pure sin wave transformer inverter, ALL wall outlet and alternator chargers have an AC current, the way we get 12 or 14 volts from the charger or alternator is by using capacitors and diodes and such to just give out the measured out voltage, its still in a sin wave format or in most cases (bad for AGM) step as its more commonly referred to. the Solar cell is giving a strait 12v output yes, BUT thats bad. it needs to be ramped and controlled, only Noco's and other high end charger/ maintainers have this ramp cycle. This solar setup just has an off and on switch of 13 to 14 volts. thats bad for maintaining but its better than nothing i suppose as it probably does very little actual useful charging. Maintaining the current flow vs the actual charge is important vs just charging a few amps and then discharging at night, and over and over.
Maybe i was not clear, im not very good at using words
I'd like to know what kind of scope he has that detects SIN waves. Both of my Agilents detect sine waves. lol
This coming from a DUDE who thinks an engine may be salvageable after finding piles of metal shavings in an oil filter. The same DUDE who thinks his Cayenne has 3 transfer cases.
i did not say that the engine was salvageable, i said it could be and that the metal could be from something NON piston/ sleeve/ related
Im Sorry, not everyone knows what an oscilloscope is, but if you do any work on cars seriously you have one. especially these cars and the timing chain job.
I see battery tender discussions are about the same as oil discussions. I'll throw my fuel into the fire. I use a CTEK 40-206 MXS 5.0 charger/maintainer for my cars. It does a great job on both the AGM batteries in the Cayenne and the Stelvio, and on the calcium battery in the Rangie. There are dedicated AGM and standard calcium/lead acid modes depending on what type of battery you are charging/maintaining.
I will now wait to hear how much it sucks...
Your battery is a AGM, it requires a SIN wave charge, the charger you have and most cheap stuff out there is a square SIN wave format.
Since DC has 0 frequency and is therefore a flatline, I'm looking forward to being enlightened by your vast knowledge of batteries and chargers.
The following 2 users liked this post by 19psi:
Devil'sAdvocate (08-24-2022),
Philip Tan (10-31-2022)
I too use a CTEK. I thought everyone did to be honest. Every forum I've ever been to has always recommended CTEK. The Porsche branded charger you buy at the dealer is a CTEK with a sticker on it.
charsiuboar (12-01-2022)
And yet you said this:
Tell us more about this sin (FIXED THAT FOR YOU) wave charge that a DC battery requires. I'm especially interested to know about the square sin (FIXED THAT FOR YOU) wave format on a device with a DC output. What type of DC sin (FIXED THAT FOR YOU) wave is produced by the more expensive battery chargers? What sine wave is produced by an alternator that converts AC to a DC output through a bridge rectifier?
A Full bridge rectifier does not take out the sin wave; they just make a squiggly DC output that still has a wave format to it. Capacitors, regulators, and resistors do that to enough that we get a "flat line" output enough that we can say that the DC current is within a specific tolerance. It still has a wave to it and always will. The CHEAP chargers. All have a stepped voltage because they are cheap. This turning ON and OFF is bad for AGM's BUT the soft curves of the sin wave from quality chargers and ALL ALTERNATORS are actually helpful to AGM's and the AC output is very specific to helping maintain the charge of a quality car and its battery. Stepping voltages and ramps are especially helpful. If you think a strait volt from a charger is good for the battery then you’re in the dark ignorance of car mechanics.
LOL go take your multimeter and put it on your battery leads on any car with an alternator... not a generator.... and switch to AC... If you do not know how to diagnose using electrical tools then I’m not going to bother wasting time on such ignorance. You have no idea but I would be happy to explain if you were willing to learn.
I suggest you start with some common electrical tools and also search on what the difference is between a pure sin wave transformer inverter is vs just an inverter.
I highly suggest you go check out electrobooms channel on YouTube, its perfect for 101 "electricity for dummies" like yourself to get started.
I’m taking about the chargers and maintainers we all use, and those all have a sin pulse and thus the argument of making a $300 AGM last for more than a few years. Again go check out the AC output from your alternator, you will be surprised.
I was going to go with those as there also a very nice high end unit but i already got into noco's and running 12 years now on them. seeing as there founded in 1914... i just stuck with them and never looked back as there a bit less in price than the Cteck at the time i purchased them. they do feel like the same part, might even be, im not a guru on that level of chargers LOL. i just know what worked and why the others did not.
And I was walking down the street one day
A pretty lady looked at me and said
Her Cayenne had stopped cold dead
And I said
Check the foot wells for moisture
She said
I don't have time to look around
And I said
Replace the battery
And I was walking down the street one day being pushed and shoved
By people trying to beat the frequency of the signal
We've all got time enough to ponder why
Does anybody really know if DC truly exists in a flat line
If so I can't imagine how
Everybody's worryin'
I can't see past the next wave step
I don't know, I don't know-ow
And I said
Replace the battery
The following 2 users liked this post by phatz:
19psi (08-24-2022),
Tell us more about this sine wave charge that a DC battery requires. I'm especially interested to know about the square sine wave format on a device with a DC output. What type of DC sine wave is produced by the more expensive battery chargers? What sine wave is produced by an alternator that converts AC to a DC output through a bridge rectifier?
I personally use "sin()" when writing mathematical equations, and "sine" when writing in a sentence as you do here, which I believe is a common style here in English speaking countries, at least. From that quora page, it shows that "sine" is actually a non-mathematical word in some countries, so it makes sense that they might not use it to mean a sinusoid function there. While I don't have a CTEK charger or even an oscilloscope, I do know a lot, including how to work the google machine.
Not really interested in shooting holes in all the less clearly explainable errors in parts of this discussion. Just fact checking the fact check.
19psi (08-24-2022)
1. It's 2022, anyone can Google SIN wave and see what comes up. Please stop trying to save face.
2.
Explain this SINE wave charge that an AGM battery requires. What is the frequency that's best for an AGM battery? At what reasonable timebase do we see this sine wave? Answer this and cite a source or please don't bother going any further.
3. I'm willing to take one of my scopes out in the garage and do tests. I'll test it on the Cayenne, another test on an inexpensive Harbor Freight maintainer, a 40+ year old 15 amp charger, a new Stanley 15 amp with AGM setting....and I even have a NOCO Genius to compare with (which you should be familiar with as you own one).
You WILL tell me what settings to enter into my scope (will post photo below) and where to attach probes, along with engine on, engine off, charging and not charging.
4. You do the same tests with your scope, post them here and we'll compare results.
I'll start:
Cheapest of the cheap, a less than $10 Harbor Freight battery maintainer on a motorcycle battery.
Timebase is 5 µs/division and pretty much a flatline with slight noise. Certainly no sine wave and also no square wave as you said cheap chargers output.
NOCO Genius 2. Regular 12 volt setting on the same motorcycle battery. Same timebase.
NOCO Genius 2 on AGM setting. Same battery and same timebase. Still NO sine wave.
And so no one thinks I'm making things up, here are the two chargers I used.
I can also use my 4 channel scope to confirm results if need be.
2.
I'll start:
The following 6 users liked this post by 19psi:
oldskewel (08-25-2022),
PepperLuv (12-01-2022),
Petza914 (08-24-2022),
phatz (08-24-2022),
Philip Tan (10-31-2022),
and 1 others liked this post.
