Changing Power Steering Cooler
So I got bumper off and all that's left is the crash bar. I've loosen the intercoolers and can reach the crash bar clamps with a screwdriver.
What's the trick to removing these clips?
the clip I want to remove...
Anyone have the part# for this bolt? The PO had been here before so one is missing.
Another missing bolt; part# anyone?
To replace the power steering cooler on your CTTS, the steps are -
- remove bumper.
- loosen left/passenger intercooler and shift to give access the crash bar clip.
- remove driver side intercooler and intake pipping. You need the clearance to remove the clip as the AC lines are in the way.
- remove rear crash bar clips, remove crash bar bolts and slide crash bar out.
- unhook the cooler and drain the ps fluid. Remove cooler, install new one, refill with 202, button everything back up.
See this post for good pics https://rennlist.com/forums/cayenne-...t-project.html
I added a catch can over 4k miles ago, and when I drained the drivers side there was very little oil. There was way more oil before the catch can was installed.
clip at end of crash bar.
driver side clip location
clip
- remove bumper.
clip
