TPMS when aired down?
How do you get the TPMS to stop beeping at you when aired down for offroad? It's pretty annoying and won't go away. It makes you select an option -> change tire, spare wheel, etc. but keeps coming back. The computer knows it's running all terrain tires but insists on proper air pressure.
Thanks!
Thanks!
On a 958 Cayenne, with something like a LAUNCH x431 V+, it is possible to add an tire type entry to the TPMS menu (or alter the existing entries) to whatever you want, like 25psi F/R, and then you can select that TPMS selection when off-roading so you can not have an annoying TPMS warning when running lower pressure. On a 957, it might also be possible - dunno, but it's worth a look if you have a LAUNCH tool like the x431 that allows one to recode various things (or know someone who has one you can borrow).
99sxxx (08-07-2020)
