Help identifying vacuum lines behind engine
I had to take the intake manifold off of my '06 Turbo. Now when I'm putting everything back together, I cannot remember where all the vacuum lines behind intake manifold go. There is one obvious, large pipe that comes from front that has the locking tabs, then on the bank2 side there are smaller hoses that come from bypass valve. Upper hose goes to intake manifold and has a small round one-way-valve in the middle. The lower small hose (the one I'm holding in the picture) going from bypass valve to intake manifold has a small tee in the middle. One end goes to manifold, one end goes to bypass valve. The middle one is the one I cannot remember. That hose would be #14 in the second picture.
