Traction control issue
Found it!
It was fuse seven on the passenger's side (5 amp fuse). Someone had pulled it and not replaced it. It says something about telephone and transfer control module - does anyone know what would cause that fuse to blow?
Since I have the new module I will just have it programmed. But before I do i want to fix the fuse fault (if there is one).
I do have an after market radio - would that cause it?
First, for anyone searching the fuse number 7 on passenger side was definitely it. The sport mode works again and all the lights went off.
Second, I need to ask a question - their is a wheel diagram that flashes up in the console when I switch to a lower differential lock. There is also what looks like a warning light in the speedometer that also comes on - is that normal?
