And while you are in there - change out your headlight harness. Mine on both sides were ridiculous, most of the insulation was crumbling off. Maybe a phantom dipped headlight warning???
$35 each from Pelican. Probably a good investment.
Something we'll each deal with eventually. I realized mine were bad in the process of replacing a dead bulb last year. Ended up just replacing all bulbs and both pigtails. Not expensive.
Inspect the contacts for the turn signal bulb holder while you have the headlamp out and clean them up. They have a habit of wearing or arcing through and then you may be stuck with replacing the entire assembly.
