2006 CS coolant leak
looks like either the water pump or the thermostat housing is leaking from the spray pattern?
The pulley attached to the pump is solid with no play.
Pillow (10-15-2019)
Until you remove the serpentine belt and spin the pulley by hand and wiggle it, it's very difficult to ascertain that it has "no play" because it's always under a pretty high load from the belt tensioner, which keeps you from being able to wiggle it.
Thanks for the tip, didn't think of that initially.
With the belt off, the pulley still has no play.
Wonder if I just swap out the pump and gasket, then put the system under pressure with my AIRLIFT -
will that be enough to test if the gaskets at the thermostat are bad/good
This is a great way to do it as you can troubleshoot without the system being full of coolant and having to drain it all again in the event of a leak.
Just did exactly this with my airlift and leak detector on my 928 and found a defect at the passenger side water bridge.
If the airlift holds vacuum for a while, stick the end in the jugs with the 50/50 mix of coolant and distilled water and fill it up.
Finally had time this past weekend to tackle this job.
I wound up only needing to replace the Water Pump, and did not have to tear into the rest of the engine to do the thermostat.
After I replaced the water pump I used the AirLift and the negative pressure test held !
So after cleaning the throttle body and mass air flow sensor, and putting in a new serpentine belt as well. I put it all back together and she's running strong again.
The most difficult part of the repair was removing the lower radiator hose to drain the fluid.
It did not want to come off
Love it when the project goes as predicted, as they only do that about half the time. Glad you're back in business.
