Turn Signal Stalk will not reset
2006 Cayenne.
Turn signals work, but the stalk will not return to the neutral position after the turn (left or right) is completed.
My guess is that I need to replace the whole turn signal assembly, but maybe it's a simpler fix?
Unless Porsche has changed the fundamental switch design, sounds like a broken spring or switch inside the steering wheel assembly. I've replaced TS switches, but on cars with older simpler steering wheel designs. I'd check with an indie who's done it before; IIRC there a lot of tiny parts in there.
