06 CTT-S hazard lights go on when I lock the doors with the remote???
Just had the hazard lights on when I was helping someone earlier today. Now when I get out and hit the door locks with the remote teh hazard lights flash. I turned them off inside the car. On and off. Tired re-starting. Any ideas?
Thanks for the massive amount of help. ;)
I have a 958 and every so often, it decides to surprise me by showing off a new "trick" it's picked up along the way. I've learned to get out of the car, lock the doors, and way away for an hour or so. When I return, she realizes I wasn't impressed with her antics and everything goes back to normal.
Honestly though, let the pcm go to sleep and I'll bet it'll be fine the next time it awakens. Or just unplug the battery for a bit and force everything to reset. |
If I am understanding you correctly, you lock the doors and the signals flash.
Its a setting under the comfort menu- uncheck the box that says turn signals. |
Originally Posted by Red5
(Post 15919828)
Bit impatient aren't we? You posted at 7:20 PM one day, and the same evening at 12:49 AM, you make a sarcastic post to complain about not getting a response? I'll take this up with management, and see if we can assign one of our trained answer givers to monitoring just your account for questions. |
