Fault code 1426
Fault code 1426
Could anyone help me and shed some light on what the solution to this durametric error code relates to? I have a 2005 Porsche Cayenne 3.2L
The error is diagnosed by Durametric as
1426:
Control unit in steering wheel
No signal/communication
There have been a couple of old posts of people asking the same question but no solutions so it appears to be a bit of a mystery.
I have steering wheel buttons, tiptronic buttons and lights but the lights do not illuminate and neither the tiptronic and steering wheel buttons do not work.
I have checked all the fuses and they are all good.
Any help would be sincerely appreciated.
1426:
Statement of the obvious...I suggest that if that is the best you can do you should refrain from posting in future as it does not help either myself or others with the same problem in finding a resolution.
1426 is not a valid Cayenne specific fault code. There is no dedicated control unit for the steering column electronics. Many of the steering column functions go through the Gateway and other control units. You already searched and came up empty handed, there is a reason for that. I doubt you will find a diagnosis here. If you want to be led on a goose chase for the cause of your problem that is your choice. I would suggest you pay for diagnostics @ the dealer or find someone with a PIWIS. Vehicle systems specific faults (non OBD) are usually going to be proprietary to Porsche and their software. Durametric is great for some things but has it's faults and many limitations. This is the place that most Cayenne owners don't want to be in. Good luck in your search.
Does the car start and drive?
Yes it drives OK. This is the only error that durametric reports on the whole of the car.
I think it might be something to do with the steering wheel control unit. All stalks work OK Indicators, cruise, wipers and horn all work OK just not the buttons.
Also strangely on the instrument panel - the clock and odometer buttons do not work either so if anyone reading this has had the same issue then any feedback would be appreciated.
I'll look at taking the cover off the steering wheel...maybe i'll be lucky and see the harness is not connected properly or something.
