Front Wheel Bearings
I have a 2008 Cayenne S with ~ 115,000 miles. Recently there is a "whine" whenever the car is moving. It changes frequency with speed so it is leading me to believe it is probably a front wheel bearing or bearings. Has anyone had front wheel bearings replaced, and if so, approximately what was the cost? Trying to prep ahead.
Thanks, Terry Watson |
Does it change on/off throttle? How about with transmission in neutral at speed? Wheel bearings usually get progressively louder with speed, starting at lower speeds. CV axle will wary with on/off throttle, or on brakes and/or in neutral.
If the noise is at 60-80, check tire balance and for bent wheel. Can also rotate the wheels and see whether the noise follows the wheel. If above 80, check control arm bushings. What I'm trying to say is that you better have it diagnosed correctly, as guessing and throwing parts at driveline noises can get expensive quickly. Bearings on the Cayennes are beefy, but anything can fail. |
Does the noise change or vary if you do a sweeping right or left turn at speed? It could also be your front diff or transfer case. If the oil has not been changed in a while in those I would do that first and see what happens.
Originally Posted by wtsnt
(Post 15780352)
Thanks, Terry Watson I changed the front diff oil with a thicker 70W-140 and transfer case oil as well but did't change much and next I will add ceratec to the diff and change rear diff oil as well. It could be a drive shaft bearing damaged as well I think. It's been there since I got the car and didn't go worst at least. |
My experiences (in other vehicles) with failing wheel bearings is that they make a woob woob noise that is not a constant pitch. Failing wheel bearings will change pitch with speed, but it is not a constant hum. Constant hum suggests differential or some other driveline component.
