Power Steering Line Part Number (Pic Attached)
OK then, I'm putting that on my list. While I'm in there, I'm going to replace my pitiful one tone horn with a fiat air horn. Too bad I can't get the one that's on my 911, it's great.
Forgive the possibly foolish question...I discovered the same leak today. Have had the GTS up and down on the lift adjusting the Airmatic Lowering links, attempting to match the ride height L&R.
Anyway, that is Pentosin leaking correct? Same circuit/reservoir possibly as the clutch? The owners manual doesn’t really give me any detail...
My pedal gets intermittently weird at times, friction point too near the floor.
[QUOTE=sprfrkr;15781437]Clamp in place. Definitely exerts more force than the pinch clamp (without over tightening). The green residue on this line seems to indicate someone was in here before trying to address this as the line above it doesn’t have this. I could be wrong. Fingers crossed. I’ll test drive tomorrow and post results.
[/QUOTE
I have the same leak however my cooler lines look fine and I could easily slip the hose off. Is that the return hose https://parts.byersporsche.com/p/Por...534743910.html
[/QUOTE
I’m sorry that I can’t say for sure. I was nearly sure it was the line leaking, but after drying it off and turning it back on and turning the wheel, I saw the leak was the oil cooler itself, but it was very hard to tell. Sorry that is not much help.
